c oil pickup tube
Ricky G View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ricky G Quote  Post ReplyReply Direct Link To This Post Topic: c oil pickup tube
    Posted: 05 Apr 2012 at 9:06am
does oil pick up  tube have a curve in it or suppose to be straight
mine has a curve in it anyway found out mine is cracked were it screws in to the block
when i tried to remove it it broke off in the block now have to try
and remove broken piece all the pictures i have seen shows it being straight
working with a basket case some one else tore a part original problem no oil pressure
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 9:23am
All that I have seen were straight. Have a few in the shop (with the pickup end); yours for $5 plis postage. If no oil pressure, check that the pin in the back of the cam is intact; the oil pump shaft has a slot that goes over the pin...broken pin=no oil pump drive. (Been there, done that)
PM me if interested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ricky G Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 9:47am
replaced the oil pump drive pin looked ok
