C main transmission shaft removal
wisjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wisjoe Quote  Post ReplyReply Direct Link To This Post Topic: C main transmission shaft removal
    Posted: 31 May 2019 at 1:28pm
I have my C split in 3 to replace the clutch shaft and main transmission shaft. I have the pto housing off and the transmission shaft as far forward as it will go. How do I get at the snap ring so I can get the shaft all of the way out. The service manual doesn't fully explain it or I'm just not getting it. Do I have to take off the final drive housing to get at it? I think I may be in over my head. Thanks, Joe.Confused
Just living the dream, with an occasional nightmare!!!
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2019 at 3:09pm
I have always removed the finals and stripped the case bare to clean so I could inspect every part and reassembled. It has been a few years but I don't remember any disassembling problems. There is a cup in the upper back that oils the short shaft that fills with crud that would be hard to clean with the gears in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wisjoe Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2019 at 10:22pm
  With the help of a friend the transmission is apart. Waiting for a few parts and reassembly will begin. Thank you, Joe
This page was generated in 0.104 seconds.
