C.H. Wendel book....d18
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Topic: C.H. Wendel book....d18
    Posted: 21 Jan 2010 at 4:14pm
If someone could please scan and post that picture on here..that would be great.
"Better By Design"
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 6:06am
I can`t find any picture of the D18 in the book. Send me an e-mail and I`ll send you a picture of Dale`s WD46 Special.
"Burgie"
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 7:19am
I will see what I can do, it will be tomorrow though, my scanner is at home.
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 7:34am
Page 328, bottom left, with cultivators. Sorry, don't have a scanner.
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 7:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 9:05am
Thank-You
"Better By Design"
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 9:33am
Check out the decal Austin. The D-18 looks like the D-17 diesel front half bolted to a what was to become a D-19 rear half. The picture looks like a 6 cylinder gaser. I thought that I read somewhere that fuel tank capacity was a issue and a larger fuel tank is likely the main reason for the taller D-19 sheet metal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 10:02am
If you look in the D19 owners manual i belive that there are some close up pics of the D18. They have pictures of a non turbo charged diesel that i belive was the D18. Matt
Edited by Matt (Jordan,MN) - 22 Jan 2010 at 10:03am
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 10:27am
Turbo needed room under the hood so they raised the sheet metal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 12:08pm
So in this picture...it is what would become the D-19 Gas engine. But this has the D17 Hoods, front shroud and the front weight that bolts to the powersteering would have been the D-17's
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 12:42pm
I also see that the D-18 has 38" rear wheels. Not many D-19's even had 38's. I have a D-17IV diesel with 14.9 x 38". They should all have been built that way.
Brian Ahart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Ahart Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 2:00pm
Here are a couple of scans from an early D19 brochure (11/61).
Here is a retouched photo of a D18 (with full-length hood decals added).  Notice the lower hood line from the D17 hood and the smaller vertical gap between the decal and the horizontal "bump" that runs along the hood.  This one is mentioned in Norm's book on Page 94.
Here is a second photo from the same brochure.  This one has production sheet metal, but makes you wonder if the D18 designation was still used up until the last minute.  Notice the "D19" designation scribbled in by hand.
A-C Weight ID reference and other goodies at brianahart.net
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 2:57pm
So was the front axel on the D-18 like the one under the D-17 or D-19?
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 2:58pm
It probably would have had to have been the D-17 front axel...because of the bushing that goes into the front wieght thing... D-19 front axel prolly wouldnt fit in that.
"Better By Design"
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 4:23pm
The standard rear tire for a D-19 was 15.5 X 38.
Edited by Lester - 22 Jan 2010 at 4:31pm
ACD19farmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACD19farmboy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2010 at 9:05pm
the d18 would look like if you was to hook up a d17 to the d19 from the torquetube... or maby form the transmission
This page was generated in 0.176 seconds.
