Buzz saw blade speed
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Topic: Buzz saw blade speed
    Posted: 06 May 2021 at 9:34pm
What RPM should a 18" buzz saw turn at?
The mechanic always wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2021 at 10:07pm
To cut wood a blade tip ( tooth) needs to run approx 150 feet per second...
18 inch is 4.7 feet around the outside ( circumference)
150 ft / 4.7 ft = 32 rev per second
32 x 60 =  1900 RPM
running a little faster cant hurt, .... figure 2000 RPM as a " good" speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2021 at 10:10pm
Perfect, thanks. Exactly what I was looking for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2021 at 10:14pm
the 1900 rpm is for an older well used saw ( sawmill...).... a newer unit might run 2000 - 2400 rpm as the "sweet spot) ...... do NOT go to 3000 RPM on an 18 inch saw.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2021 at 9:13am
OK, thanks. I have a handheld tach and will get it dialed in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2021 at 10:41pm
I have always thought having a buzz saw would be nice help.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2021 at 8:42pm
I used to run a 30" buzz saw on Dads old 35 wc. ran it half throttle and worked fine. ---- smaller blade would have to run faster.
This page was generated in 0.168 seconds.
