building D-14 puller
Rowdey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rowdey Quote  Post ReplyReply Direct Link To This Post Topic: building D-14 puller
    Posted: 04 Oct 2016 at 12:46pm
I have a AC 433 T motor out of F-2 Combine any Ideas on where to buy mounting plate?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2016 at 1:42pm
An I-600 industrial tractor had a back plate that would fit a D-15 tractor for the 4-cylinder 433-TI engine. Don't know if that engine will fit between the side frames of a D-14, as it is narrower than a D-15.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2016 at 4:38pm
Will the 4:33 even fit between the frame rails
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2016 at 9:03pm
only if one finds an I600 or a 500 fork lift frame or 615 etc.  Also going to have to have a flywheel out of a 200 CI gas or diesel as well.   Then there is a starter
issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 6:19am
Sounds like a neat project. Our local rules would allow that swap into a D15 but not a D14 as the D14 was never factory available as a diesel.  The 433T would be a motor of the same number of cylinder by the same manufacturer as OEM. I would guess that the 433 flywheel would need to be cut down to fit inside the bellhousing and then the OEM ringgear could be used along with the OEM starter for the tractor. Although a gas starter would need a special rebuild to have torque for a diesel.  I'm only guessing but maybe the 433 backing plate could be drilled to fit the bellhousing and then the excess trimmed off.    Let us all know of your progress.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 10:19am
I have a D2200 engine assembly out of a 653 with the rear plate, flywheel, starter, hydraulic pump, etc, and looking for the front plate to mount in a D15 chassis.
The 615 with a D2200 engine is a very nicely done install from the factory, still looking for one.
Edited by JoeO(CMO) - 05 Oct 2016 at 10:21am
This page was generated in 0.227 seconds.
