Building another Puller
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: Building another Puller
    Posted: 13 Jan 2011 at 5:24pm
My daughter wants a tractor to pull and we have to paint it pink. I am trying to find the pics of the purple CA that was on here. I want to build an unstyled WC but it will not painted any off coulor. I was thinking of a CA. Only 1 local pull has a 2500 lb class, so how much weight would you have to put on to pull in the 3500 lb class. Also if I remember right there is an engine swap from one of the D tractors that can be done. Maybe a D14 with 12.4x38 and narrow front. Would the 12.4x38 look goofy on a CA. Just looking for suggestions.
Brian
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 5:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 5:31pm
RW, is that Pinky's old tractor. What size rear tires are on it. There was one posted on here that was purple with yellow decals.
Jamie NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie NC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 7:37pm
Before it was pink!
Allis tractor puller CA WC WD D17
