Building a motor, need advice
chickenmann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chickenmann Quote  Post ReplyReply Direct Link To This Post Topic: Building a motor, need advice
    Posted: 20 May 2014 at 7:21pm
I am building a puller motor and need to know a few tips, first, will WD-45 deisel rods fit into a g226 motor and is it worth the trouble? If so, does anyone have a recommendation on which piston to pair with it? I am planning on putting 190 valves in it with the tall head, using a D17 intake that has been opened up, an EGleaner camshaft and a 170 carburetor. Will this setup do anything or am I way off base and need to go in a different direction? I am a true rookie at this and would love some input.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2014 at 8:08pm
After finding someone to regrind/offset grind your crankshaft, you will have a 4 7/8" stroke instead of 4 1/2" stroke using the diesel rods. It does nothing for compression with a stock 4 inch bore piston, so you'll have to find a piston tall enough to make some compression. Also the diesel rods need a piston with wrist pin keepers or pin buttons to keep the piston pin where it belongs. Never used 190 valves and I doubt they would even be worth the trouble. "E" Gleaner camshaft is nothing different that a WC-WD-WD45-D17-170 for grind. Be careful installing different camshaft without knowing your oil pump drive teeth count. One-Seventy carb isn't anything special either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chickenmann Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2014 at 8:20pm
Ok, that helps me out, I will stay away from the diesel rods and keep the stock rods and WD45 crank that I have now, what pistons would you recommend to get more compression? Are the distillate/over 8000 feet of altitude pistons a way to go? What carburetor do you recommend instead of the 170? Thanks in advance for the help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote chickenmann Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2014 at 8:23pm
Also, I haven't purchased an oil pump yet, will an EGleaner pump fit into the WD45 pan?
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2014 at 8:35pm
go with m&w 4.125 pistons i would use stock oil pump have a cam ground and degree it in at 104 or 105 that should gain you some power oh get a MS 464 from a wd45
Edited by patrickmull - 20 May 2014 at 8:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2014 at 8:36pm
You said it was a G-226..........you have a WD-45 crank and block?? that's W-226.   "E" Gleaner oil pump fits and use the E camshaft to drive it. Kinda late to be building an engine for a Puller.....especially if you need anything special for parts.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2014 at 8:53pm
I have a set of 4 1/8" M&W pistons that I am using in my WF block. I also have a WD45 (4 1/2" stroke) crankshaft coming. Will I have any clearance problems on the head? I am having the head milled just enough to flatten it out.
Any recommendation on who to get to regrind a cam? I was hoping to get it going for this season (which is still a month away up here), but it's looking more like 2015 for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2014 at 9:05pm
If they are truly M&W model SP-46 pistons with the heart-shaped bowl, you'll need to mill off .170" or so to keep from hitting the cylinder head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2014 at 9:09pm
if they (pistons) are sp48 they will clear/ cam i would talk to wi50 on here he might have one or order one from bullet cams @ http://www.bulletcams.com/ tell them your application they will design one for you
Edited by patrickmull - 21 May 2014 at 5:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote chickenmann Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2014 at 10:28pm
Dr Allis, trying to get a motor for 2015, just trying to give nyself plenty of time to get it right
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2014 at 5:47am
I am thinking on  a new motor for next year now also for 2015
Edited by patrickmull - 21 May 2014 at 5:48am
Jasonillinois View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jasonillinois Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2014 at 6:00am
Unless you are dead set on building an engine, and can do a lot of it yourself, buying one already done is probably the cheapest route. Find someone who is getting out of pulling and buy the tractor.
This page was generated in 0.115 seconds.
