buda 344 ac 7000 swap
ratchet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ratchet Quote  Post ReplyReply Direct Link To This Post Topic: buda 344 ac 7000 swap
    Posted: 17 Jul 2012 at 6:55am
What issues will i run into on a buda 344 swap to a ac 7000Confused turbo engine in my hd6g?
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2012 at 7:34pm
The starter motor is different but the HD344 starter will work if you don't get a starter with the new motor. If you use the HD344 air cleaner there is some plumbing to be done. You have to cut a hole in the hood because the turbo exhaust comes out in a different place.
