B&S problem..
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: B&S problem..
    Posted: 29 Mar 2021 at 7:34am
OK, neighbours' B&S vtwin, 25 hp, 2002, 488hrs,has a curious and frustrating problem..
 Starts and runs at medium high speed, constant, can't vary speed with lever.
Everything is conected,even tore carb off to CONFIRM butterfly is there and moves....
If I manually push the linkage from guv to carb up, it'll slow down,but it's 'stiff'.
Naturally all this happens AFTER I tore engine apart to install new 'oil pan' gasket and a  new starter....so it's 'my fault'.
Guv springs are where they're supposed to be, adjusted guv from net... did this 2-3 times.
 I HATE to think the internals are somehow busted.....
 if the guv guts were busted, it'd rev to a zillion rpm and  kepow ??
Anyone seen this before ??
Any ideas ??
Thanks
Jay
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 7:50am
Make sure the cable is connected to the lever still. Don't ask......
Edited by thendrix - 29 Mar 2021 at 7:51am
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 8:55am
Jay
This guy may be able to help you.
He has an endless number of Videos on YouTube regarding Small Engines.
Gary
https://www.youtube.com/watch?v=CV3BcTwLXb8
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 9:01am
yeah, cable's connected....the THROTTLE cable.....sigh..had to CONFIRM that last night....
mechanically everything is as it 'should' be
guess I need to put speakers on this PC one day....
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 9:33am
I had a similar problem about 10 years ago.. Could not get to REV UP after disassembly. Thought i must have got the governor WEIGHTS inside caught or broke or ??........... Looked at all the movies on you tube and saw that the ARM that bolts on the OUTSIDE of the governor shaft is very critical in its position.. They had a procedure to rotate the shaft one way, then hold the arm in a specific position, then tighten.. I had it off just a little and made a BIG difference ..... and the governor spring has SEVERAL different possible holes to install... check the internet photos for proper hole.
that governor shaft only moves a little bit, right ?? Maybe  10- 15 degrees, so a little is a LOT !
Edited by steve(ill) - 29 Mar 2021 at 9:34am
Robert Musgrave View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 9:40am
The governor adjustment is critical.  Loosen the clamp, turn shaft and hold, and with your THIRD HAND hold the adjustment and re-tighten clamp.  Years ago, had the repair manual open to the adjustment page--didn't realize it but page turned itself and was looking at the wrong picture--no matter what I did it was running WOT.  Finally, saw that I was on the wrong page--similar diagrams for Vertical and Horizontal shaft engines, different pre-sets (clockwise vs. counterclockwise). R. Musgrave
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 12:34pm
arrrrrgh, this one's a friggin noghtmare.....
4th time adjusting the guv, 'by the book', BTW vicegrips make a GREAT 3rd hand to keep guv shaft fully CW......
had idle and fast,even inbewteen...great...go for test drive..
arrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrgh.. back to med-fast speed and throttle lever has NO effect...
Jay
it's ONLY the 1st monday of the week but ...can I go back to bed ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 4:29pm
governor controls max rpm, overspeed..... throttle sets the max operating rpm you want and works with the SPRINGS to adjust that... still think it is an adjustment problem.. Maybe a different  VERSION of the MANUAL is needed ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 5:14am
arrgh....
downloaed the OFFICIAL B&S rebuild manual, guv details same as the others online....
...so.....
today's job ,once Mr. Sun comes to visit...is to remove from rider, get on bench drain oil, tear it apart as it HAS to be 'something' inside
crazy thing is I've done lots of these in the past 3 decades, one just a MONTH before this PITA beastie...
maybe someone's telling me something ??
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 12:00pm
Wink Just replace that flux capacitor thingy ma bob.LOL One of the big chain parts stores on the south of the 49th added it to there inventory just for the trying covid times.WinkWinkWink
Edited by Ray54 - 31 Mar 2021 at 12:04pm
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 8:23pm
Found on 27 HP B&S the arm was bent and dragged - seems someone backed into some solid object and that readjusted clearance on carb setup , bent arm out and everything worked with governor actually control speed as throttle was moved
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 11:59am
well Jay, what did you find
I am still confident of this;
Wait for the Lord;
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 2:03pm
I've got a Simplicity 61" Zero Turn mower. I used it for a couple of hours a couple of weeks ago, then parked in the shop, and build a trailer hitch for it, to pull a lawn roller, then a couple days latter put it back in the barn.
 Sunday the guys came and got their boats out from winter storage. I wanted to move the ZT mower and it would not start. It has a B&S V-2.
I talk to my dealer and they said to replace the fuel pump, I did and that fixed it. That sure is a strange fuel pump, It's not very big and seems more like valves.
 The engine  also has a round thing mounted on it that fuel lines going through it, both feed and return. It's maybe 2" dia. and 6" long.
 Anyone know what it does?
 The mower is a 2013. It's a B&S engine.
Dusty
Edited by Dusty MI - 01 Apr 2021 at 2:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 2:18pm
well, tore it apart....NOTHING obvious.. 4 bits  of guv look OK...cleaned, reassembled, used last of gasketmaker goop, have to wait overnight before I pour in the oil and fire it up....
had to make an engine lifting gizmo, mounts on crankshaft ontop of flywheel. Somehow I managed to get the balance point PERFECT, so at least something went right for me.
Dusty... fuelpump is vacuum operated from a valve cover...real 'old skool' tech ! Be real careful pushing gaslines back on, else you'll break the plastic spigots and then have to spend anotehr $11 to buy anotehr pump and filter from China ( I now have 4 setes in stock.....don't ask why !' )
curious am I , about the 2by 6 'device'... please post a picture when you can...something I havent seen before
You should ALWAYS shutoff gasline, run engine 'dry', to remove all the gas and water from the fuelpump. Winter has a nasty habit of freezing the water in the gas and busting those pumps....... OK NOW you know why I have 4 on the shelf.....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 2:29pm
Dusty, is it some type of fuel FILTER ?  Like Jay, i have never seen anything like you described.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2021 at 7:37am
ARRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRGH
adjusted as per the official B&S manual....
left gasketmaker to set over night....
got on,started up ,idled ok(cold here).
ran throttle up....won't go down
ARRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRGH
anyone got some C4 I can have ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2021 at 7:53am
Jay,
 Dont let this get the better of you. Its some little thing, spring on the wrong way? something hitting something else. Assembly slightly wonky. Do you have another unit near by that you can look at too? Just some basic things I do when something is not working. Did it work when he brought it to you?
Dont have the answer here. Did you take pictures prior to the tear down?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2021 at 9:53am
arrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrgh
this is driving me NUTZ..
replaced the guvlever,springs,throttle mechanism(shouldn't matter but only so many straws in a bale, right)
push out into the cold...
starts up above idle....warm it up mid idle, has full, can throttle down to idle, high, med ,low, high....little rough but needs a 'good run'...as it sits, it 'seems' fine (been down this road before)..
go for test drive, full out..down to driveway and back.....
stuck at full throttle......same as before
arrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrgh
dang frustrating
came in for a leaky oilpan gasket and starter....2 months ago...
never EVER had one do this and everything looks/moves 'by the book'.
one of life's mysteries I suppose
IF I could find a rider with a 22-25HP engine, it'd be swapped out PDQ
ohwell, off for a ride aroud the neighbourhood
thanks for letting me vent...
Jay
Kansas99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2021 at 10:11am
Jay, I once took a 4 wheeler to the dealer that wouldn't shift, he looked at it and asked me if I had a pickup I didn't like.  I said yes at least one, he then told me to put the 4 wheeler in the back of the pickup and set the whole works on fire and collect insurance. LOL  Just a idea. Wink
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2021 at 10:20am
check the coils and make sure both are fireing and the diodes that go to the kill wire on the coils are not bad  been there  10 years ago when our shop was replaceing  alot of those crankcase gaskets we learned that you always replace the gov. assy. no matter what  and now that is standard procdeure on all brands when we open the case
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2021 at 2:52pm
Hay Dusty...
I'm thinking it's a samll 'reservoior' tank for the engine....
gas tank->fuel filter->reservoir->pump->engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2021 at 3:00pm
rear view....
fuel filter in lower leftunder '71 of ruler....
owner's manual of machine 'should' talk about it,or a 'parts book' will.....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2021 at 3:01pm
..so now I'm reassembling my 22hp engine,course with the shutdown getting SAE30 oil will be 'fun' AND I need to find some parts 'next door'......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2021 at 5:49pm
rear view....
Jay
The manual doesn't say anything about it.
It's sealed and it has a tube coming from the gas tank hooked to it and another one going to the engine. Also the tubes are not removal and the canaster is sealed.
Thanks Jay for posting the picture.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2021 at 6:19am
looks like the part......
some kind of 'pollution control' part....
while it might not be your EXACT unit...kinda looks similar....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 9:38am
Ok, I cheated...
bought a complete Craftsman PGT9000 (26HP Kohler/54" deck) for $800
one day, I'll get back to the B&S from Hell, maybe
have to 'reassemble' my ridingblower and the other rider and TRY to find the 1 1/4" socket that's hiding in the garage.....
oh well, it's sunny and getting warmer.
Jay
