B&S 22 hp VEE engine carb
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: B&S 22 hp VEE engine carb
    Posted: 12 Mar 2026 at 10:17pm
have a 2005 Husqvarna 22 HP BRIGGS - 54 inch deck - 3speed HI/LO garden tractor that i have used a lot.. 21 year old and NEVER worked on the carb... Now it has a sputter / cough at anything below 1000 RPM... thought it might be the plugs, so i cleaned them - looked OK... thought it has 21 year old CARB, maybe needs a clean.. Took it apart ( double barrel) and all the gaskets and o-rings are BRITTLE !! .
Looked on line for a KIT and they are about $12.... Saw that you could buy a China CARB for $18. that fits 21- 22- 23- 24 - 25 HP engines... EVERRY VEE engine they ever built ?? HOw can that be ???.... Well, i bought a Chink carb for 2 chain saws, a weed eater and a leaf blower over the last 5 years and they are all GREAT... so i thought, WHY NOT, Only $18 bucks !!!
Installed yesterday and fired it up.. RUNS GREAT !!.... Idle was about 1000 RPM so i dropped that a little with the idle screw.. other than that NO MODS NEEDED ! Read on line that the plastic manifold can warp and suck air and cause  "bad idle"... mine was pretty much flat, but i put a thin layer of Permatex on it anyway !
I have had GREAT LUCK with this little China Carbs..
Edited by steve(ill) - 12 Mar 2026 at 10:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2026 at 6:18am
GREAT, I 've also had GREAT success with those 'cheap china carbs' . Keep several on the shelf.
Yes ago, Honda wanted $230+ for carb only, 9Hp. I swapped one off my 9HP 'offshore' engine. 1st pull, started and ran perfect. Since guy knew carb was $230, he was happy to pay me $300 to have his machine 'up and running'. Cost me $20 to replace the carb.
What I don't understand is how Kubota can sell me a rear tire, on rim with valve , full of air for $340, yet the tire only is $500 !
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2026 at 9:35am
well... like i sai... a box of 4 gaskets was $12.... but a MACHINED ALUMINUM carb with 14 different metal parts AND THE GASKETS was $18.... figure that out !
20 years ago that NIKKI double barrel carb was built in Japan... several years back they opened a manufacturing plant in China... i would BET that a NEW ENGINE comes with the CHINA CARB.. and the OEM sells them $18. CHINA CARBS for $250.
Edited by steve(ill) - 13 Mar 2026 at 9:37am
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2026 at 9:51am
Been my luck also with those carbs.  Original one goes in the trash, new one from china goes on and you are off and to the races.  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2026 at 10:01am
On 3rd one on leaf blower...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2026 at 10:11am
2 stroke blower ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2026 at 1:21pm
almost EVERY weed eater , chain saw and blower sold is a 2 stroke.... I had a 4 stroke weed eater about 20 years ago...only one i ever saw.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2026 at 2:10pm
Gee, lots of them for sale , north of the 49th.
I've got 7 2stroke chainsaws that will go this Spring( when it comes). Tired of the 'no start' nonsense. Be happy to get $50 for all of them at the yard sale.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2026 at 2:25pm
i always grab a new plug and CHECK FOR SPARK... If you got that, then get the $10. China CARB !!! ..... I have done that 3-4 times in the last 10 years.. before that i was "throwing them away" !!
