B&S 22 hp VEE engine carb
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: B&S 22 hp VEE engine carb
    Posted: 4 hours 38 minutes ago at 10:17pm
have a 2005 Husqvarna 22 HP BRIGGS - 54 inch deck - 3speed HI/LO garden tractor that i have used a lot.. 21 year old and NEVER worked on the carb... Now it has a sputter / cough at anything below 1000 RPM... thought it might be the plugs, so i cleaned them - looked OK... thought it has 21 year old CARB, maybe needs a clean.. Took it apart ( double barrel) and all the gaskets and o-rings are BRITTLE !! .
Looked on line for a KIT and they are about $12.... Saw that you could buy a China CARB for $18. that fits 21- 22- 23- 24 - 25 HP engines... EVERRY VEE engine they ever built ?? HOw can that be ???.... Well, i bought a Chink carb for 2 chain saws, a weed eater and a leaf blower over the last 5 years and they are all GREAT... so i thought, WHY NOT, Only $18 bucks !!!
Installed yesterday and fired it up.. RUNS GREAT !!.... Idle was about 1000 RPM so i dropped that a little with the idle screw.. other than that NO MODS NEEDED ! Read on line that the plastic manifold can warp and suck air and cause  "bad idle"... mine was pretty much flat, but i put a thin layer of Permatex on it anyway !
I have had GREAT LUCK with this little China Carbs..
Edited by steve(ill) - 4 hours 36 minutes ago at 10:19pm
