Brush Cutter Windrows |
Mosin9130
Joined: 23 Jul 2012 Location: North Texas Points: 136 |
Topic: Brush Cutter WindrowsPosted: 06 Oct 2024 at 1:25pm |
Needing some advice here guys. I have a new Deere RC 8M pull type brush cutter (solid deck w/ 2 spindles) that I use on the D19 gas. Wonderful mowing combination and brush cutting is my favorite thing to do on the farm!
However, the most frustrating thing is that the mower leaves behind two windrows. Am I doing something wrong here? Or, is this just how dual spindles cutters work? What gets me is that when the highway right-aways are cut (yes, typically 15-20' batwings), it looks so nice and well cut with no windrows whereas my pasture looks horrible. Would a batwing configuration solve this problem? ![]() ![]() Edited by Mosin9130 - 06 Oct 2024 at 1:26pm |
'56 WD 45...'63 D15 II...'66 D17 IV
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8402 |
Posted: 06 Oct 2024 at 1:55pm |
Are running the engine at the PTO mark on the tachometer? Don’t be a putt putt around the pasture just a little above idle, open that mother up!
Michael V (NM)
Posted: 06 Oct 2024 at 5:05pm |
Hmmm,, JD musta changed the rotation direction,, my antique JD 707 mower throws the windrow to the middle,,,unless ya go in reverse, then it throws them to the outside,thats at full PTO rpm. It's a similar mower, only its a 14' cut
I have a 5 or 6' bush hog that is a single blade and throws a windrow also,, so,,, maybe that's just the nature of the beast..? Don't know how the hiway dept. does thiers,, but around here they cut pretty high,,,like 6 inches or more so the windrows don't show as much... Edited by Michael V (NM) - 06 Oct 2024 at 5:11pm |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35691 |
Posted: 07 Oct 2024 at 3:25am |
My 8’ Bush Hog has twin blade gears and only windrows when ran too slow, at PTO rpm it leaves disorganized cuttings.
klinemar
Joined: 14 Sep 2009 Location: Michigan Points: 8074 |
Posted: 07 Oct 2024 at 5:20am |
There are more than one factors for leaving a window. My disc mower conditioner will leave strips in certain conditions, height of crop being cut,ground speed and sharpness of blades. PTO speed can contribute by not throwing the discharge properly. Also moisture either in dew on the crop or greener crop. You will just have to experiment and find the right combination.
Mosin9130
Posted: 07 Oct 2024 at 11:12am |
I think you all may be on to something with PTO speed being the driving factor. On my D19, the needle is in the 540 range but on the low side. "Giving it more gas" doesn't move it any further into the zone so maybe the mower isn't turning as sufficient as it should.
Thinking back on when I was cutting a bunch of Johnson grass, I don't remember it leaving windrows but I did slow down some but, that grass is "stem'ier" than the prairie grass in the picture above. Reading through forums and watching a YT video or two, the question (debate) of sharpening brush cutter blades was discussed alot and of course, PTO speed. I'm betting that 1) my blades need a sharpening and 2) my PTO speed needs to increase. As for #1, the debate was that if you cut brush, the duller the better whereas if it's pasture grass, the sharper the better. Most of my cutting involves areas that have already been cleared of brush and it's just grass so sharpening makes sense. Some said a good "brush" blade is 1/8" at the edge while a "grass" blade is below 1/16" at the edge (as sharpened). For #2, I need to look at the D19 more and if see if there is something limiting me getting to that ideal 540 zone. I can put another tractor on to test it. Thinking about the highway crews, there is no doubt they wind those mowers up at full throttle and let 'em rip.
Edited by Mosin9130 - 07 Oct 2024 at 11:13am |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25263 |
Thanks(1)
Posted: 07 Oct 2024 at 11:26am |
Anyone who says 'dull is better' has NEVER shaved with a very,very slightly dull straight razor.......
Mosin9130
Posted: 07 Oct 2024 at 12:16pm |
Haha, isn't that the truth and why I go thru shaving blades like I own stock with them.
Had something to do with leaving a "shattered cut" across the brush stem that would aid in killing it vs a nice razor cut. I'm assuming "duller is better" meant something along the lines of "less sharp" like one is used to on a lawnmower.
DMiller
Posted: 07 Oct 2024 at 6:12pm |
Only time that was spoken to me was clearing Scrub Brush with my 3008, was going to buy replacement blades but the guy at the counter noted "Want the Blades to BEAT the brush apart, Splayed Stems and trunks do NOT resprout". Installed new blades second cutting year, did a great job, much as a Giant Lawn Mower.
Lars(wi)
Posted: 08 Oct 2024 at 7:16am |
The ‘clean’ cut, ie; sharp blade vs a dull blade, was the criticism of the early discbine or haybine debate. Many early on were unhappy, the ‘regrowth’ of alfalfa was slower if mowed with a discbine instead of a haybine.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55292 |
Posted: 08 Oct 2024 at 3:25pm |
Main reason for sharpening blades is fuel consumption!
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 10 Oct 2024 at 9:35pm |
mine leaves two small windrows also one on each side even when its up 6 inches
