Broken Tach on 7040
NYREDPOWER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NYREDPOWER Quote  Post ReplyReply Direct Link To This Post Topic: Broken Tach on 7040
    Posted: 03 Mar 2011 at 9:03pm
Ive been getting to know my 7040. I understand it is common for the tach to be broken what should I do to fix it thanks
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 9:18pm
Is it broken or don't work?   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote NYREDPOWER Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 9:21pm
it does not work
monitordoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monitordoc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 10:59pm
 NEIHOFF (SPELLING) ALTERNATORS DID A NUMBER ON MANY 70 AND 80 SERIES TACHS. MOST ARE REPAIRABLE.
 PM ME FOR MORE INFO.
WD,D17-S4,180,D21
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 6:39am
Since the day I got it my 7040 tach has not worked.  Hr meter yes, tachometer no. I licked my finger and drew a line on the dash and thats where the throttle lever goes.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 7:54am
Don't know which alt. you have, but if it is a delco with the stub plugin on back the connection could be the problem. Could be a set of windings burned up in alt. Should be a small brown wire hooked to alt. check for bad connection in plug in between back of motor and fire wall.   MACK
jmm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmm Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 2:32pm
As a matter of interest:  I had the same problem and when I replaced the alt I used a cheapy model for a GM (fit perfect) and opened it up and tapped the tach wire before the rectifier.  works good!
