Broken leaf spring under the engine
Andymac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andymac Quote  Post ReplyReply Direct Link To This Post Topic: Broken leaf spring under the engine
    Posted: 16 hours 54 minutes ago at 6:44pm
Hi All,
I've broken 2 leaf springs on my HD6, does anyone know if there is an aftermarket spring that can be purchased? I'm in New Zealand.
Is it possible to slide out the 2 broken ones and replace them without taking the whole leaf pack off? Any tips or tricks on the best way to do this would be appreciated.
Thanks in advance.
tom51 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom51 Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 25 minutes ago at 9:13pm
A good welder can repair them seen it done in the past .
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 36 minutes ago at 1:02am
Archers auto springs in Rotorua should be able to make you some new ones.
I had mine out last year; pin had been welded in; I ended up having to remove all the U bolts and slide spring pack out, leaving saddle in place.
Won,t matter if lower leaves are a heavier grade thickness, they need it.
tits tyres and tracks
they all cost you money
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 18 minutes ago at 6:20am
Unlikely a welder could actually repair  it. Springs are usually 5160 steel and the welding operation would destroy the heat treat.
 best to remove haul into spring shop, wait an hour, pay  some coins and be happy.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 44 minutes ago at 10:54am
I've welded several main leafs back together to get back to a shop, or out of any impeding way. Never would I trust a weld repair to go back into service on this, or a truck type application.
I believe most any leaf spring shop can help you out easily. Years ago, I had a spring pack made up for an HD7 and I just pulled the complete assembly out and the spring shop built a new one while I waited.
That's All Folks!
This page was generated in 0.168 seconds.
