Brillion test run
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: Brillion test run
    Posted: 29 Jul 2023 at 12:16am
Here are a few photos from yesterday evenings test run....
Over last winter
I freed up the seed box gears,
made a doubler between the seed boxs as it was frail and flexing. Also
Freed up the seed slide in the front box and the seed drop gears for the tinny seeds.
Extreemly tedious job. This seeder sat outside and everything was rusted togeter.
This seeder was headed for the scrap yard but I saved it.
It dropped seed as it should.
And
I still have seed deflector to install....
[IMG]uploads/2474/20230728_205240.jtogether.
Edited by Macon Rounds - 29 Jul 2023 at 12:50am
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2023 at 5:21am
Wow! Sweet results from such an intricate rebuild. Congrats! Brillions that size go for many thousands at auctions around here!
Blue Skies and Tail Winds
                          Dana
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2023 at 6:36am
I plant all my hay fields with it. You will be really happy with the results
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2023 at 8:11am
How about bringing that to Indiana in 3 weeks to reseed about 1 acre of lawn? Just kidding - those are very handy and do a super job!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2023 at 9:05am
How's that work? Just sprinkle seed between rollers from the box above?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2023 at 10:06am
The rollers are off-set, first set makes a groove, Second roller/packers cover it up.....
Can't set the depth, just roll and go....
only thing you can control is seed application amount.
I can already see inconsistent packing were rear tractor tires run and other field imperfections.
Those seeds don't get covered at all. Grrrr !
We'll see how things grow.
Edited by Macon Rounds - 29 Jul 2023 at 10:09am
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2023 at 10:14am
I've got a 10' that's newer. Works OK, but leaves some seed on top of the ground not covered at all. I think a conventional grain drill with a legume box set for very light penetration followed with cultipacker works a little better.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2023 at 12:54pm
Weld a couple of spring tooth harrow in front to break up the tire tracks
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2023 at 7:51pm
I think ours is 10’ but a pull type. Did well when dad used it to plant Alfalfa. It’s a heavy piece of equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 2:46pm
Ready to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 2:47pm
need dust/grease cap as seen in photo above.
Front axle is installed, rear axle missing cap.
Anyone know of brillion parts dealer ?
Thanks in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 5:21pm
The newer brillions have 4 teeth per side to scratch up wheel tracks, mounted fwd of the front roller...  Should be easy enough to bodge up with pipe and rake teeth.
Scroll through the images in this link:  https://landoll.com/farm-equipment/agricultural-seeders/
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 9:59pm
I had some heavy tedder tines I was gonna use but
I really like the "S" shaped spring tillage shoes. I have very limited space between rear tire and seeder, so if there not silly expensive ill go that way...
Was not sure my idea of spring tines were gonna work anyway. Ground packs hard with tire weight.
Edited by Macon Rounds - 31 Jul 2023 at 1:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 11:25pm
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2023 at 6:56am
When I was a kid (many, many years ago!), I remember a thing on Dad's grain drill to roughen tire tracks. It flipped down and had a hole to pin it down (or up). The mounts looked like pieces of leaf spring that had two rows of (what looked like) heavy rake teeth (like in your picture above).
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2023 at 4:48pm
It takes 28 clicks to the right, in the above link to get to the picture I was referring to...Wink
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2023 at 8:19pm
Nice work on the drill.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2023 at 9:32pm
Thanks
the prep work on the metal wasn't what i would do on a tractor restoration but it will keep it from rusting ....
Found an axle dust/grease cap that I purchased....
And the "S" springs are $36 each so I think I'll get a piece of pipe and see if those heavy tedder springs I have will do the work of tilling up after the tractor tires...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2023 at 4:32am
Originally posted by Macon Rounds Macon Rounds wrote:
Thanks
About half that at agri-supply (plus shipping)...Wink
