Briggs model NP remote throttle linkage
Heliarc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heliarc Quote  Post ReplyReply Direct Link To This Post Topic: Briggs model NP remote throttle linkage
    Posted: 03 Aug 2025 at 5:11pm
Working on a Bolens 12B walk behind tractor. I believe it's a power ho but not 100%. Someone was in to it and between the throttle bell crank and the wind vane governor, something is missing or not hooked up. It's set up for a remote throttle control via cable to the handlebar. I'd like to at least set it up for the customer that it's constantly at a decent RPM but using the governor so he's not tempted to bypass the governor and rev the guts out of it. Anyone have a decent pic of how the linkage between throttle and governor ought to be? Whatever setup you have I can probably make something work. I just want to make sure the engine will be OK before I let it go.
Edited by Heliarc - 03 Aug 2025 at 5:12pm
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2025 at 8:21am
I have a Bolens walk behind here---not sure the model. its back in the shed behind the tb tillers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2025 at 1:07pm
every small engine should have a hard link to the governor arm... and a spring to set the governed RPM....
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2025 at 1:22pm
