Briggs Engine ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Briggs Engine ??
    Posted: 09 Dec 2021 at 6:06pm
A friend of mine has a Huskvarna (sp) riding mower , model 2348LS, that can only be started by removing 1 of the plugs prior to cranking and then re-installing the plug/wire while the engine is running Confused. He recently went to a "dealership" that pedals some parts for this manufacturer for the mower deck drive belt and was telling the counter guy the starting scenario  and a "tech" said that the cam was bad Ouch ?? The engine runs perfectly once running according to the owner, so he's confused on why a cam replacement is the fix Embarrassed ? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2021 at 6:31pm
yeesh that makes ZERO sense..but a lot of CENTS to the 'dealer' for the 'repair'
2348LS sounds like a 23HP with 48" deck. If so  B&S vtwins need to have their valves adjusted (always MORE gap needed),almost yearly. Info is on the web,need a 7/16"open ended and torx key(?).The 'trick is to lift front of rider up high, so oil under the valve covers drains into the block. I let it do that overnight. You 'should' buy 2 new valve cover gaskets, though 'gasket maker' in a tube works fine.Most of the time spent is finding TDC,then a simple adjust for the gap,When happy ,Put valave covers and gaskets on, lower, have a coffee THEN start her up.
I do 1-2 a year. The 'signal' that it needs to be done is 'hard starting', 'battery won't spin the engine'....'slooooow turn over'.
Maybe this isn't it, but ther's NO way it needs a camshaft.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2021 at 6:42pm
My experience says you’re right on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2021 at 7:01pm
YEP... if it only turns 1/4 turn and STOPS... needs valves adjusted.. Could be too tight OR too loose...They got to be just right to get the proper compression/ timing.
Edited by steve(ill) - 09 Dec 2021 at 7:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2021 at 7:07pm
This assumes your battery is not over 6 years old !! ... and the cables are GOOD.
Edited by steve(ill) - 09 Dec 2021 at 7:08pm
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2021 at 11:03pm
check the valve lash first but we have had that engine come throught the shop a few times with a sheared flywheel key and only off just a few degrees  also we did have one v twin and single with bad atuomatic compression release wich means you have to replace the cam
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2021 at 5:59am
We had a Scotts with that vtwin. Had to adjust valves about twice a year here to. Not hard just aggravating
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2021 at 6:36am
Removing a plug.....automatic compression release not working.....which is the cam.......INTERESTING.Smile
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2021 at 7:07am
That must be the norm for these days.  I've heard of a dozen stories of the cam problem. That made me figure it was just lazy kids telling customers that so they would leave and not come back.  Still made me wonder why the cam is going bad.  I'm 67 and never heard of this problem before the last couple years.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2021 at 7:31am
How far back does this go? I have a Craftsman riding lawn tractor, that starts very hard even with new battery and clean battery contacts. Always have, as long as I’ve had it. Bought used from an Ariens dealer probably 15 years ago. When starting it will turn over about 1/2 a revaluation, then stop, turn key off, then try again, may need to do it 2-3 times before it starts to turn over normal, then start. It is a 2 cylinder, will get the engine model number next week, and report back here.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2021 at 8:37am
Lars, if that is an opposed flat head Briggs, I have one doing the exact same thing.  I will be pulling the heads and scraping the carbon out.  Have done this before.  It collects so much carbon due to the head configuration that the compression is raised.  Last time (years ago) I did that and it went back to starting like new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2021 at 8:47am
Lars, mine is a 24 HP V twin about 17 years old... Did EXACTLY what you said... I could rotate the crank just over TDC on once cylinder and then it was good to go... Adjusted the valves and problem solved.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2021 at 4:10pm
With the flywheel being off a "few" degrees, did it run smooth after starting ?
Thanks to all of you guys that have replied !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2021 at 7:29pm
Single Cyl Briggs OHV 11-14hp do the same thing.  Had three so far two on Snapper Mowers(11hp) and a 14hp at the shop I work, take cover off adjust valves and All is Good Again as allows the Compression release to function.  Cams are soft, if run too long as this or do not change oil routinely end up with a bad cam.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2021 at 8:55pm
And assuming you don't drive an extended cab short bed pickup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2021 at 3:34pm
DANG them 4 ft Truck Beds !!!!
Happy Laughing Sticker - Happy Laughing Lol Stickers
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2021 at 5:08pm
Maybe the B/S logo lost its black, and ran into the red?Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 6:13pm
You would know, I believe that you run one Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 6:16pm
Thanks for a helpful reply Jack Hole ClapClap
Ride those coat tails WinkWink !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 6:34pm
Sorry, I couldn't resist.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 7:26pm
FreeGas asks for it............. thats why we go along !! Wink
This page was generated in 0.207 seconds.
