Briggs 23D swap
KS Husker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KS Husker Quote  Post ReplyReply Direct Link To This Post Topic: Briggs 23D swap
    Posted: 30 Dec 2010 at 5:34am
I have a Briggs 23D in my Simplicity Landlord. Needs overhaul, burning lots of oil. I have a chance to buy a good running model 23 I would like to put in it. What is the difference between a 23 and a 23D? I know a 23 is older but anything else?
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2010 at 10:12am
Here's a forum with a lot of knowledgeable A-C/Simplicity garden tractor people on it.
http://www.simpletractors.com/club2/forum.asp?FORUM_ID=7
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2010 at 10:22am
The changes I know of are mainly in the ignition system. The earliest 23 engines have an ignition system known as Magna-Matic. It's not the same as Magnatron since it still uses points where Magnatron is breakerless.  Magna-Matic has a timing advance mechanism. These engines will have the coil under the flywheel. Later model engines use the typical external coil next to the rim of the flywheel. There are other possible differences such as ball bearing mounted crank vs a plain bushing and a Stellite exhaust valve. All things considered, the early 23 would be better in my opinion.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2010 at 11:56am
Seems a lot of these engine swaps just take a little head scratching and it can be done. Replaced the Kohler in my New Holland S16 with Techumsa the ifrst time and now have a Honda 18 HP in it , other S16 I have now has a 16 B&S 2 cyl opposed in it , all horizontal crank. Just put 18 HP B&S into older DutzAlis 616 and changed right in, just had to change one thing on crab.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Post Options Post Options   Thanks (0) Thanks(0)   Quote KS Husker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 5:49am
Got model 23 picked up saturday. Only difference I see is the coil under flywheel. Runs good. Plowed garden sunday just to see how it would pull. Ready for some snow so I can get it out  and play some more.
