BRAKES A/C FL40 FORKLIFT
JRM914 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JRM914 Quote  Post ReplyReply Direct Link To This Post Topic: BRAKES A/C FL40 FORKLIFT
    Posted: 07 Jan 2013 at 11:49am
i NEED SOME HELP I REPAIRED THE ENGINE ON THIS FORK LIFT IT RUNS SWEET OWNER IS SO HAPPTY HE WANTS ME TO FIX THE BRAKES.  i HAVE A PARTS MANUAL NO SERVICE MANUAL CAN ANY ONE HELP ME WITH GETTING THE BRAKE DRUMS OFF OR WHAT IS NECESSARY TO GET AT THE BRAKE SHOES? I HAVE PULLED THE SPINDAL NUT OFF AND REMOVED THE OUTER BEARING THE WHEEL MOVES A LITTLE BUT NOT MUCH ANY HELP WOULD BE GREAT
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2013 at 5:00pm
you'll have to adjust the brakes down...cant remember which type of adjuster you have ...there will be a hole in the backing plate or a hole in the drum...hole in backing plate may look like a drum bung
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2013 at 7:27pm
with a full modle and ser.# i might be able to get pics at work we were a dealer for the ac's and still have the microfilms
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2013 at 5:25pm
ok i did a little looking at work today, you truck has "slide bar" brake adjusters. there should be 2 slots in the backing plate, one on each side. you should be able to use a large screwdriver in those slots to compress the slide. when you pull the drum be carefull it has a bull gear in it and will be very heavy. once the drum is off you will see a tin grease shield covering the brakes it unbolts easily. the brakes are pretty basic after that. you didn't say what the brake problem is but if it is a low pedal especially on the first presss of the pedal then those adjusted bars could be the problem. if you do any work i would recomend replacing them.
This page was generated in 0.230 seconds.
