Brake rod
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Topic: Brake rod
    Posted: 01 Jun 2023 at 7:03pm
Looking for a good used or NOS brake rod for a Series 4 D17, part number 237331, only need one, but might take a couple if someone has them.  Not sure how this one got broken, but the hook end is missing on the left one, Smile.
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2023 at 9:42pm
I broke one several years ago. You might want to look, my memory is bad, I think the left and right were different. But please check that out. Like I said memory is like burnt toast.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2023 at 9:53pm
I wondered if they were different as well, checked my parts book, and according to that, they are the same.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2023 at 9:55pm
Thanks for the advice 200Tom1, Smile
Jasonw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jasonw Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2023 at 7:07am
They are still available from Agco, about $55 per rod.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2023 at 10:16am
The hook on the end is where they usually did break. You can cut it off a little run a 3/8" die up on the remaining rod 2 inches and get a 3/8" threaded yoke to screw on in place of the broken hook.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2023 at 9:21pm
AGCO has new ones
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2023 at 9:48pm
The way that the Dr. describes is better, stronger, and provides an easier way to adjust the brake.
DCAC View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2023 at 10:05pm
Many thanks for all the replies, Gentlemen!  I hadn't checked with AGCO when I put this post up, was kind of a spur of the moment decision, and had originally thought of fixing it like the Good Doctor suggested.  I thought I'd check with you all on here before proceeding with that.  I did buy a 3/8" threaded hardware hook and threaded coupler, and that's how I'll go for now.  I can order a new rod if this doesn't work.  Thanks again, everyone!  Smile
This page was generated in 0.453 seconds.
