Brake lites ‘95 Suburban
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Brake lites ‘95 Suburban
    Posted: 27 Mar 2022 at 10:43pm
No brake lites on the taillight cluster, no 4-ways.
3rd brake lite works above the rear doors.
Signals, running lites all work.
All fuses, relays appear good.
Do the brake lites run thru signal/hazard switch on the steering column?
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 11:07pm
I would say Yes - check under dash on brake lite switch - but if year upper light works than would say it's in connection under back - then again if the turn signals work -
 You have a problem !
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2022 at 11:14pm
The circuit board that the bulbs plug into from the wire harness are notorious for going bad from my experience. Most parts stores keep them in stock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 7:09am
check the connector at the base of the steering column ? could be loose ??
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 8:01am
most often its the circuit board in the tail light housing. sometimes you can remove the bulbs clean the socket and install new bulbs. most auto parts stores stock the circuit boards and there fairly cheep. I think the last ones i changed were $50 for the pair and they had new bulbs installed. From the factory the bulb sockets had a wax grease coating and last a long time. once you change out the original bulbs moisture and dirt get between the bulbs and contacts a little while later new bulbs wont fix it because the contacts corrode and wear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 10:04am
All sockets have that grease in them. Just the bulb filaments for the brakes don’t come on when stepping in the brake pedal(dual filament bulbs). Running lites, and signals work. 3rd brake lite works.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 10:23am
Bad ground on the tail lights.  Happened on my dad's 79 GMC many years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 10:24am
um, sounds silly but.... have you confirmed the bulbs ARE good ? Actually tested with battery ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 5:57pm
Hate to tell ya, T/S Switch is trashed.  Brake light goes to Signal Sw, then to lights, As has Signals the wiring and bulbs are still good, the Third Eye lamp is off the Brake switch directly so the T/S switch is Bad.
Edited by DMiller - 28 Mar 2022 at 5:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 8:35pm
Dave is probably right... "NORMALLY" the  TURN and BRAKE lights are the same filament / wire.... its the SWITCH that picks which one to send down the wire to rear light. ( BRAKE wire and TURN wire both feed the switch... so could be the BRAKE wire TO switch).
If it was the tail light working, and no brakes or turn... then the circuit board / bulb. .... but on an old truck, you should INSPECT the sockets and board.
Edited by steve(ill) - 28 Mar 2022 at 8:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2022 at 10:26pm
Was thinking probably the switch stalk, when I push the thingy for the hazards, they don’t work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 8:19am
If you have TILT WHEEL, and use it a lot... you can flex the wires and have a few break or plug pull off the switch....... if not, look at the switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 8:21am
Be sure to tie TWO strong,long  strings on the 'loom'(wire harness) when you pull it out to fix or replace it.......
If you don't, well, I TOLD you.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 8:53am
Thanks for the replies, gonna send it to a shop, gotta replace one of the front universal joints, and drivers side inside door latch isn’t working either, gotta roll down the window and open from outside. If used trucks weren’t so expensive, I probably would send this gooberment motors ‘down the road’.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2022 at 3:25am
X2 what steve said...tilt wheels will also affesct your headlights soon too!
This page was generated in 0.176 seconds.
