|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| Brake fluid question |
| Post Reply   |
| bobkyllo   Orange Level     Joined: 14 Sep 2009 Location: minnesota Points: 1561 |  Post Options  Thanks(0)  Quote  Reply  Topic: Brake fluid question Posted: 30 Jul 2021 at 2:49am |
   This question goes to two different groups. Group one is auto shop owners/mechanics group two is just the general group here.  Watching YouTube and a channel was suggesting that mechanics buy this certain brake fluid tester because it'll make the shop so much money. So my question is do you guys that are mechanics do many brake fluid flushes. How about you weekend warriors do you concern your self with your brake fluid aside from the fact that there is enough. | |
| Thad in AR.   Orange Level Access     Joined: 12 Sep 2009 Location: Arkansas Points: 9668 |  Post Options  Thanks(0)  Quote  Reply  Posted: 30 Jul 2021 at 5:48am |
   I live in Humid Arkansas. I change the fluid in my motorcycle every year. My trucks not so much even though I feel a person should flush those once a year as well. I just recently replaced a wheel cylinder on my work truck. I know for a fact it was 4 years old. It looked like it had sat in a swamp for 30 years | |
| plummerscarin   Orange Level Access   Joined: 22 Jun 2015 Location: ia Points: 3980 |  Post Options  Thanks(0)  Quote  Reply  Posted: 30 Jul 2021 at 6:28am |
   Seems every couple years I have to replace a brake line so it gets changed whether I want to or not. But yes, fluid should be changed once in a while
| Lars(wi)   Orange Level Access     Joined: 14 Sep 2009 Location: Permian Basin Points: 8153 |  Post Options  Thanks(0)  Quote  Reply  Posted: 30 Jul 2021 at 6:32am |
   In my younger days, I replaced a brake line or two, on a couple of old beaters. That is one of the items I now take to a mechanic for repair, I don’t fool around with brakes.  What they do as far as the brake fluid is up to them. I routinely check the the brake fluid on all my vehicles, and top off if needed.
| Ed (Ont)   Orange Level     Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1506 |  Post Options  Thanks(0)  Quote  Reply  Posted: 30 Jul 2021 at 10:13am |
   Just suck the old stuff out of master and put some fresh stuff in every few years. Better than not doing anything.
| dee_veloper   Orange Level   Joined: 12 Apr 2021 Location: USA Points: 1168 |  Post Options  Thanks(0)  Quote  Reply  Posted: 30 Jul 2021 at 12:27pm |
 That's what a lot of shops do and they charge for a complete flush | |
     Don't confuse my personality with my attitude.  My personality is who I am. My attitude depends on who you are. | |
| DaveKamp   Orange Level Access     Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6089 |  Post Options  Thanks(0)  Quote  Reply  Posted: 30 Jul 2021 at 4:00pm |
| I second Thad-  My motorcycles get the calipers pulled off, bleeders screws broken loose, and all the old fluid pumped out from top to bottom, forced out by new fluid. Reason:  DOT4 brake fluid is hygroscopic:  It absorbs moisture from the air, and that moisture includes contaminants that, once mixed with the coctail of master cylinder, calipers, and hoses, turns into a brownish-black gak that plugs up everything, especially the return hole on the master cylinder. My GL is due for a new set of brake lines.  Next time I do it, I'll be replacing the pads, resurfacing the disks, replacing the flexible lines with braided stainless, adding a crossover tube to the front calipers, and replacing the front brake MC with one from a larger road bike... and replacing the REAR MC with one that doesn't have a second segment to control the front caliper.  Reason?  The GL1200 is set up for 'integrated braking', which is where you step on the brake pedal, and applies the rear and ONE of the fronts, while the front MC controls only ONE caliper, which means when I grab the front brake, I only get HALF the available braking power. But yes, a full flush, but many auto shops will 'advertise' and charge you for such a service, without actually doing anything.  DIY, man! | |
     Ten Amendments, Ten Commandments, and one Golden Rule solve most every problem.  Citrus hand-cleaner with Pumice does the rest.
| HD6GTOM   Orange Level     Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |  Post Options  Thanks(0)  Quote  Reply  Posted: 30 Jul 2021 at 4:03pm |
   Had my motor home done in June.  On top of a new master cylinder they did a complete flush and checked the brakes.  She's ready to head to someplace cooler.  Brake fluid looked like runny brown baby poo.  Probably been in there since 1996.
| JTOOL   Silver Level Access   Joined: 28 Feb 2021 Location: 64720 Points: 346 |  Post Options  Thanks(0)  Quote  Reply  Posted: 30 Jul 2021 at 7:58pm |
   @bobkyllo; In all of my years as a mechanic, I don't recall myself or anyone flushing the brake system as preventative maintenance. My gut tells me that flushing (in a mechanic shop) is kind of a scam but on the other hand maybe some of the problems I/we did deal with could have been prevented if PM had been done. In my personal/weekend warrior life, I've only had to deal with hard part wear/failures.
| fixer1958   Orange Level     Joined: 13 Feb 2010 Location: kansas Points: 2434 |  Post Options  Thanks(0)  Quote  Reply  Posted: 31 Jul 2021 at 7:39am |
   Been doing brake flushes for 20+ years. Part of the scheduled maintenance if anyone has ever bothered to pay attention to that. It does make a difference in brake reliability/longevity/performance and all that other happy chit.
 All brake fluid is hygroscopic. Depends on the equipment you are using to do it. What type of vehicle it is etc. Use synthetic brake fluid if you really want to get assnine about it. Doesn't absorb moisture as much. Good for long term storage vehicles. You should go with new parts though. Restores etc.  Flushes or not it's not going to reduce some of the brake failures that happen. Rusty brake lines, collapsed hoses etc. Most of that is manufacturer issues. They know they have a problem and still keep churning them out. Just what I see and I see a lot. | |
| DMiller   Orange Level Access   Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34341 |  Post Options  Thanks(0)  Quote  Reply  Posted: 31 Jul 2021 at 9:14am |
   Each brake job I perform on my own machines, bleed until get New Fluid from bleeders, start at furthest wheel then back to the closest as last bled out.  Not an issue with aged fluid at that point,  All flushed of contaminants and corrosion compounds.
| DaveKamp   Orange Level Access     Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6089 |  Post Options  Thanks(0)  Quote  Reply  Posted: 01 Aug 2021 at 9:45pm |
 DOT 3,4, and 5.1 are glycol-based, and thus, hygroscopic. DOT 5 is silicone based, non-hygroscopic. | |
| bobkyllo   Orange Level     Joined: 14 Sep 2009 Location: minnesota Points: 1561 |  Post Options  Thanks(0)  Quote  Reply  Posted: 03 Aug 2021 at 10:37pm |
   Thank you everyone for your thoughts. It seems as if we are divided a bit on this subject. As I'm torn also. I want to do best for my customers but I'm unsure how to sell the service as some might find it hokus pokus.
| fixer1958   Orange Level     Joined: 13 Feb 2010 Location: kansas Points: 2434 |  Post Options  Thanks(0)  Quote  Reply  Posted: 04 Aug 2021 at 6:45am |
   Find a BG rep. Stuff is pretty good. They furnish the equipment.
| Stan IL&TN   Orange Level   Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |  Post Options  Thanks(0)  Quote  Reply  Posted: 04 Aug 2021 at 8:25pm |
   My 1994 is my daily driver.  Been flushed 3 times in the 27 years.  One master cylinder.  Front brake hoses.  Rear wheel brake cylinders replaced.
     1957 WD45 dad's first AC 1968 one-seventy 1956 F40 Ferguson | |
| shameless dude   Orange Level     Joined: 10 Apr 2017 Location: east NE Points: 13607 |  Post Options  Thanks(0)  Quote  Reply  Posted: 04 Aug 2021 at 9:30pm |
   i don't ever recall changing the brake fluid in the older cars/trucks, pre-1990. but i've sucked out the old stuff from about all of the vehicles made after 1990 several times. i too just take a turkey baster and suck out as much as i can, and refill with a new bottle of fluid. sure makes the steering turn easier for a long time. when the steering gets harder, i suck out another pump and refill. i'm sure the older stuff will work it's way back up to the tank then i can suck that older stuff out. my '15 burb needs it done now. have done the '98 pickup several times thru the years.
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
