brake adjustment wd45 |
Post Reply |
johnny
Silver Level Joined: 12 Sep 2009 Location: shawneetown, il Points: 317 |
Posted: 05 Feb 2012 at 10:00pm |
I replaced some trans gears in my wd45 and I am going back together with it now. I have the final drives back in and the brakes on. The manual says to use the rear set screw center the brakes around the drum. Since i cant see much what is the best way to center them or how to know when they are centered?
thanks
johnny
Ryan Renko
Orange Level Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2321 |
If you take the inspection brake covers off that are held on by the two bolts up top you can see better. Make sure the rear set screw seats in the rear shoe properly and just center them up. Ryan
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8235 |
It goes something like this......you tighten the nut on top to get the shoe clearance tightened up so you get the pedal travel you need,then you use the set screw in the back side to move the assembly to a position which ends up with both shoes traveling the same amount to touch drum. You have to work the pedal and watch the shoes move to decide which one is moving the most and adjust accordingly. Can be a little tricky in that you see more of one than the other and the way things move in there is a bit deceptive. Pay attention and don't get fooled. If you don't get it close(and close is okay-don't have to be perfect) you will have one shoe dragging the drum and wear it out quickly. This is all done with the covers off. Hope that helps.
Any time you adjust the free play you need to check the shoe travel and readjust the set screw if necessary.
Edited by SteveM C/IL - 05 Feb 2012 at 10:29pm |
Brian G. NY
Orange Level Joined: 12 Sep 2009 Location: 12194 Points: 2241 |
Jack the wheel off the ground so you can turn it while you are doing the adjustment
johnny
Thanks for the input. I am gone for the week, but when i get home plan pn adjusting them up.
thanks
johnny
Brian G. NY
I'm "bumping" this up for your info.
AC WD45
Orange Level Joined: 28 Sep 2009 Location: Mid Michigan Points: 2013 |
I am giving this a bump, as the there is a lot of excellent info in such a short post. Perhaps the admin team will see fit to move this topic to the knowledge base subsection.
German Shepherd dad
Lon(MN)
Orange Level Joined: 11 Sep 2009 Location: Elk River,MN Points: 1966 |
I have seen many where the tab broke off the brake shoe so the set screw will not center the shoe. Something to check. If you need brake parts I have a shelf full.
http://lonsallischalmers.com
Post Reply | |
