Boy, did I get lucky, XT grill?
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: Boy, did I get lucky, XT grill?
    Posted: 20 Mar 2025 at 4:41pm
Last week I was using our XT and front end loader to clear dead branches around the perimeter of the fields general cleanup, carry branches and sticks to the burn pile. A day or so later I went to get the tractor out of the shed and noticed the grill was not on the front of the tractor. First I almost got sick to my stomach because it's a pretty good grill, so we started backtracking and looking for it. We found it on top of the burn pile evidently when I was pushing the branches and debris up a stick popped the grill off and I didn't even see it was missing just happy that it's still in pretty good shape. So for anyone out there pushing brush keep an eye on your grill!
LeonB Mo
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2025 at 4:49pm
   Sounds like a 'Grille Guard' is in order!
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2025 at 6:31pm
When I went through my XT back in 2016 I decided to remove the terrible latches and install a back plate, drill and tap it. Now 4 bolts hold my precious grill in place. No more worries of it coming unlatched and getting run over. Very easy to remove for service. I’m glad you didn’t damage it, they are expensive if you can find a good one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2025 at 6:36pm
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2025 at 7:25pm
Great Idea!!! and it looks good too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2025 at 9:03pm
Thanks Unit3
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2025 at 8:51am
I won't pass a correct police inspection, but I put rubber hooks and latches on mine to hold it in place.
Darrel
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2025 at 10:19am
AC720. That is the way to repair it! Looks better and works better than factory. Sometimes you can improve on a factory idea. Smile
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2025 at 11:46am
I do something similar to AC720. I use a 1/4 x 1 x 3 inch plate. I welded nuts on the back side but you could tap threads also. One got tractor was made for 3/8 bolts other one only used 1/4.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2025 at 4:11pm
That looks nice. A cleaner look and better attachment
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2025 at 7:58pm
I do like the looks of that. Will be on the "to do list" for this winter.
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2025 at 9:03pm
Thanks everyone, it has worked very well.
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2025 at 8:31pm
I adjusted the stock latches so that they were snug, then wrapped a small nylon zip tie around each latch to prevent them from popping open. Use UV resistant zip ties.
