blower motor amp draw
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Topic: blower motor amp draw
    Posted: 27 Aug 2018 at 9:34pm
Hey guys, took my '89 mustang out for first time in a couple weeks and when I turned on the vent the blower motor was running slower than usual, and it pulled my voltmeter down a good bit, less than 13 volts though I don't have my multimeter here right now. I didn't have this issue the last time I drove it, what could change suddenly like that from sitting? I'm thinking bad blower motor or resistor, battery was new last spring and alt was replaced a few years ago with not many miles. Going on a fairly long trip next week so trying to catch it early if something needs replaced.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2018 at 11:27pm
Sons 2010 ford did the same thing, blower motor was bad. It took all of 20 minutes to replace it. His 17 year old son replaced it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2018 at 2:55am
partial mouse nest?
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2018 at 7:18am
Will turning on the headlights cause the voltmeter to drop also?  Might be a charging or battery issue if that is the case.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2018 at 8:49am
I can agree with the mouse nest aspect, pull the motor and see what lays inside the housing, could just be a corroded up motor but doubtful.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2018 at 6:03pm
I cleaned a mouse nest out of vents this spring and fixed inlet screen where they got in, fan and motor looked fine then. There is nothing to suggest another nest, no smell or strange sounds from fan area.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2018 at 6:24pm
check and see if the squirrel cage spins free.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 10:11am
The fan bearing or bearings could of gotten mouse pissed up.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 1:49pm
I would be suprised if the running amperage is over 2 amps and shouldn't be noticeable. Run a hot wire direct from the battery and check the draw on it. You have load tested the battery first?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 8:10pm
Got my testing equipment here today, the battery and charging system tested fine, no mouse nests, the voltage drop with the fan on high was only about .2 volts so the volt gauge in the car was being a little over dramatic. The blower fan seemed to run a little faster today but still weak, so I'm thinking the fan itself just must be getting tired all of a sudden. At least no big troubles before the road trip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 8:59pm
If there was a mouse nest in the blower wheel, you'd know it. They will vibrate the dash big time. Probably the brushes are worn. If that's the case I've seen them melt the resistor and connectors. Get it fixed before you go on a long trip. The fuse will be 40 amps so there's plenty of current capability to melt things.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2018 at 7:33am
If that Volt Meter is not ignored you may want to inspect the grounds to the body, I did have a bad Negative battery cable a few years back on a '91 ford Explorer that would increase the resistance to charging and the body/frame ground was not all that great where every drop in voltage would cause a increase in amp loads. The definer for me was hearing slight changes as to blower motor speed varying on its own, inside courtesy lights being a little dimmer at times, dash light flicker while driving and so on.
This page was generated in 0.219 seconds.
