Block Heater
Northern View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Quote  Post ReplyReply Direct Link To This Post Topic: Block Heater
    Posted: 21 Dec 2013 at 2:37pm
I have a HD-5 and I like to know if there is a place for a block heater for the 2-71 detroit?
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2013 at 12:57pm
NO - you would need a lower hose heater or tank heater - heating the head is about all you can accomplish and that will heat part of block
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2013 at 3:18pm
a dipstick heater will help keep the oil warm but may not do too much to help it start but I never had any trouble with a little ether.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2013 at 3:31pm
If your looking to warm oil and part of engine those magnetic heaters will work also .
Either into the small 1/4 " pipe plug on blower housing is how I start my machine
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2013 at 10:31pm
Thanks guys, I'll look for a heater for the lower hose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2013 at 10:24am
Tank heaters work quite well. They also come in different Wattage's for engine sizes. Zero Start is one company off the top of my head for starters...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2013 at 4:21am
KAT's is another for hose installations and magnetic units, also Northern Tool
http://www.fivestarmanufacturing.com/Kat_s
This page was generated in 0.840 seconds.
