Block heater woes -301
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2026 at 6:25pm
Hey!  That picture looks familiar!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2026 at 8:03pm
Told ya I was learning....more work to grab someone's pic off a text and get it here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2026 at 8:12pm
This mine. You can see where heater is. The orange one belongs to another forum member. My fuel filter blocks port his uses for heater.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2026 at 8:15pm
Mine
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2026 at 8:23pm
Easiest plan B is put a tank heater on but I don't like where it needs positioned Drain plug on side of block up to tstat hsg. I may pull that filter etc off to see what.
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2026 at 9:31pm
No worries!  I don’t mind that you used it!
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2026 at 11:57pm
I had to look at my tractor engine, whoever did the swap moved the filter housing down, it also has a dual filter. I will try to link the picture so you can zoom in on it.
https://photos.app.goo.gl/upuHsvhmEyBiamBh9
It looks like that would make it a lot easier to put the heater in, and it would be more centered in the block.
Ted
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2026 at 8:55am
Seems like it is going to be a lot of work to go to a Tank Heater.  Wouldn't the 1000 watt heater be less heat and less likely to boil the coolant?  Is that worth a try or did the rep say that won't work at all?  Was the rep a Zerostart tech person?   Does it make sense to ask them?  I know you have burnt up every one you tried so I understand why you don't want to try the 1000 watt version or maybe even the 400 watt version.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2026 at 10:21am
Talked to zerostart engineer. He wasn't comfortable with 1000wt at that location. A 700 maybe but cost add up burning em up doing trial and error. A tank heater could mount on frame rail and have about 20 inches of hose for both inlet and outlet. Literature on tanks say to keep out of weather. It would be somewhat under fender and I plan to keep it under roof so that might be okay. I just like "clean" installs. Sometimes your choices are limited. The tank i looked at was recommended for up to 26? qt system. Mine is around 34qt. It was 1500wt. This is getting complicated....
Edited by SteveM C/IL - 03 Feb 2026 at 10:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2026 at 1:00pm
TedN...could you get a pic of the other side? I see your engine has that water manifold going around the back of head too headed to oil cooler? My water pump is different than a tractor but application list loader and Gleaner M&L 301's as same.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2026 at 1:10pm
I would try a 700 watt and see if that works. It seems like that would heat slower and not boil.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2026 at 4:10pm
https://photos.app.goo.gl/GPif8dscg9Zu2VjU6
I think this is the correct link.
Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2026 at 7:11pm
That's good to know you completely explored that with Zerostart.  Given how complicated things are getting, I might blow another $130 on the 700 watt version, then go to the tank heater after that.  I had a tank heater and while it worked, it took 3-4 times longer to heat up.  Of course, tank heater is better than no heat at all.  It is crazy how big of a rats nest this has become but old equipment always has it's challenges.  I know you will whip it.  Good news is that you can take a picture and post it now when you finally get success. Smile
Edited by calico190xt68 - 03 Feb 2026 at 7:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2026 at 10:27pm
Yes Ted. That's what I was after. On my loader the rear cooler is as yours and cools the oil. The cooler connected to the water pump is for the trans but I don't see any connections or plumbing for such. Mine has two 1/2 in npt connectors welded on the side that hoses hook to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2026 at 10:29pm
The combine used a tube in place of the trans oil cooler used on the loaders
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2026 at 10:30pm
Well that makes sense!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2026 at 9:51pm
the latest....put a 1000wt heater in my loader. Straight version like the 1500 i've burnt out. If this fails I'll have to modify my f/filter mount and use the bent one like a tractor uses. It's a 1000wt.  Certain it would work but just couldn't help myself and tried this first. Experience is a great teacher.
Edited by SteveM C/IL - 11 Feb 2026 at 9:54pm
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2026 at 5:48am
Why not a magnetic oil pan heater (500W ??) and your coolant 700w (or less if that size is burning up) heater ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2026 at 7:23am
I think it is worth a try given the level work for the other plan.  Hope it works!
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2026 at 10:32am
I have enjoyed this thread, I am now thinking about putting a heater in my seriesIII. I don't want to hijack the thread but I noticed the loader engine has a double belt setup. Does anyone know the part number for the water pump pulley and where I could get one? I looked at some Gleaner books but so far all I have found looks to be single groove.
Thank you in advance.
Ted
edit: I just realized the 7000 uses a double belt system, I should be able to figure it out from here
Edited by TedN - 12 Feb 2026 at 10:55am
DanWi View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2026 at 11:34am
Ted, the 200 had double belts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2026 at 6:31pm
I got one of them magnetic heaters somewhere but the time or two I put it on my 220 pan it didn't heat worth a crap. Was on for several hrs and pan wasn't warm enough to tell a difference. The Allis heater for a 301 is 1000wt and there's 2 members at least  here that use them and they don't fail so I'm thinking maybe this straight heater will be ok. They are both in the same water jacket just the tractor one is in the "middle" and mine is in the front end where a tractor water pump feeds the block. I would rather have plenty of heat because when it's zero and it's in a tin shed,I want it to START!!! I can't say how effective a 700wt heater would be.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2026 at 7:06am
I had, basically, the same experience with the magnetic heater. I bought to put on my subcompact tractor for extreme cold weather. After being on for over two hours, the oil pan still felt cold, but maybe not quite as cold as the rest of the engine.
I ended up giving it to a neighbor who put in on his water pump in the barn for his beef cows.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 35 minutes ago at 7:31am
Curious if you have turned on the 1000 watt heater yet or if it has burned up like the others? I would think it would do it pretty soon if it was creating an air pocket like the rest.
