Block heater woes -301 |
Page <12 |
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1108 |
Posted: 02 Feb 2026 at 6:25pm |
Hey! That picture looks familiar!
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8889 |
Posted: 02 Feb 2026 at 8:03pm |
Told ya I was learning....more work to grab someone's pic off a text and get it here.
SteveM C/IL
Posted: 02 Feb 2026 at 8:12pm |
![]() This mine. You can see where heater is. The orange one belongs to another forum member. My fuel filter blocks port his uses for heater. |
SteveM C/IL
Posted: 02 Feb 2026 at 8:15pm |
![]() Mine |
SteveM C/IL
Posted: 02 Feb 2026 at 8:23pm |
Easiest plan B is put a tank heater on but I don't like where it needs positioned Drain plug on side of block up to tstat hsg. I may pull that filter etc off to see what.
im4racin
Posted: 02 Feb 2026 at 9:31pm |
No worries! I don’t mind that you used it!
TedN
Joined: 30 Apr 2025 Location: Central WA Points: 143 |
Posted: 02 Feb 2026 at 11:57pm |
I had to look at my tractor engine, whoever did the swap moved the filter housing down, it also has a dual filter. I will try to link the picture so you can zoom in on it.
https://photos.app.goo.gl/upuHsvhmEyBiamBh9 It looks like that would make it a lot easier to put the heater in, and it would be more centered in the block. Ted |
calico190xt68
Joined: 12 Jan 2017 Location: Frankton, IN Points: 899 |
Posted: 03 Feb 2026 at 8:55am |
Seems like it is going to be a lot of work to go to a Tank Heater. Wouldn't the 1000 watt heater be less heat and less likely to boil the coolant? Is that worth a try or did the rep say that won't work at all? Was the rep a Zerostart tech person? Does it make sense to ask them? I know you have burnt up every one you tried so I understand why you don't want to try the 1000 watt version or maybe even the 400 watt version.
SteveM C/IL
Posted: 03 Feb 2026 at 10:21am |
Talked to zerostart engineer. He wasn't comfortable with 1000wt at that location. A 700 maybe but cost add up burning em up doing trial and error. A tank heater could mount on frame rail and have about 20 inches of hose for both inlet and outlet. Literature on tanks say to keep out of weather. It would be somewhat under fender and I plan to keep it under roof so that might be okay. I just like "clean" installs. Sometimes your choices are limited. The tank i looked at was recommended for up to 26? qt system. Mine is around 34qt. It was 1500wt. This is getting complicated....
Edited by SteveM C/IL - 03 Feb 2026 at 10:25am |
SteveM C/IL
Posted: 03 Feb 2026 at 1:00pm |
TedN...could you get a pic of the other side? I see your engine has that water manifold going around the back of head too headed to oil cooler? My water pump is different than a tractor but application list loader and Gleaner M&L 301's as same.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3109 |
Posted: 03 Feb 2026 at 1:10pm |
I would try a 700 watt and see if that works. It seems like that would heat slower and not boil.
TedN
Posted: 03 Feb 2026 at 4:10pm |
calico190xt68
Posted: 03 Feb 2026 at 7:11pm |
That's good to know you completely explored that with Zerostart. Given how complicated things are getting, I might blow another $130 on the 700 watt version, then go to the tank heater after that. I had a tank heater and while it worked, it took 3-4 times longer to heat up. Of course, tank heater is better than no heat at all. It is crazy how big of a rats nest this has become but old equipment always has it's challenges. I know you will whip it. Good news is that you can take a picture and post it now when you finally get success.
![]() Edited by calico190xt68 - 03 Feb 2026 at 7:13pm |
SteveM C/IL
Posted: 03 Feb 2026 at 10:27pm |
Yes Ted. That's what I was after. On my loader the rear cooler is as yours and cools the oil. The cooler connected to the water pump is for the trans but I don't see any connections or plumbing for such. Mine has two 1/2 in npt connectors welded on the side that hoses hook to.
im4racin
Posted: 03 Feb 2026 at 10:29pm |
The combine used a tube in place of the trans oil cooler used on the loaders
SteveM C/IL
Posted: 03 Feb 2026 at 10:30pm |
Well that makes sense!
SteveM C/IL
Posted: 11 Feb 2026 at 9:51pm |
the latest....put a 1000wt heater in my loader. Straight version like the 1500 i've burnt out. If this fails I'll have to modify my f/filter mount and use the bent one like a tractor uses. It's a 1000wt. Certain it would work but just couldn't help myself and tried this first. Experience is a great teacher.
Edited by SteveM C/IL - 11 Feb 2026 at 9:54pm |
Stan R
Posted: 22 hours 22 minutes ago at 5:48am |
Why not a magnetic oil pan heater (500W ??) and your coolant 700w (or less if that size is burning up) heater ?
calico190xt68
Posted: 20 hours 47 minutes ago at 7:23am |
I think it is worth a try given the level work for the other plan. Hope it works!
TedN
Posted: 17 hours 38 minutes ago at 10:32am |
I have enjoyed this thread, I am now thinking about putting a heater in my seriesIII. I don't want to hijack the thread but I noticed the loader engine has a double belt setup. Does anyone know the part number for the water pump pulley and where I could get one? I looked at some Gleaner books but so far all I have found looks to be single groove.
Thank you in advance. Ted edit: I just realized the 7000 uses a double belt system, I should be able to figure it out from here Edited by TedN - 17 hours 15 minutes ago at 10:55am |
DanWi
Thanks(1)
Posted: 16 hours 36 minutes ago at 11:34am |
Ted, the 200 had double belts.
SteveM C/IL
Posted: 9 hours 39 minutes ago at 6:31pm |
I got one of them magnetic heaters somewhere but the time or two I put it on my 220 pan it didn't heat worth a crap. Was on for several hrs and pan wasn't warm enough to tell a difference. The Allis heater for a 301 is 1000wt and there's 2 members at least here that use them and they don't fail so I'm thinking maybe this straight heater will be ok. They are both in the same water jacket just the tractor one is in the "middle" and mine is in the front end where a tractor water pump feeds the block. I would rather have plenty of heat because when it's zero and it's in a tin shed,I want it to START!!! I can't say how effective a 700wt heater would be.
Page <12 |
