Block Heater for HD5G
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: Block Heater for HD5G
    Posted: 14 Dec 2021 at 8:01pm
My Son-in-law's HD5G with 2-71 DD could definitely benefit by having some sort of 120 VAC engine block heater; any recommendations will be appreciated.
Thanks for the help Smile
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2021 at 8:10pm
Block heater won't work but a tank heater and line from block drain back to thermostat area will , or a lower hose heater in that hose from radiator to water pump .
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2021 at 4:49am
Google says this one is what you want.  Not sure where it mounts.
Like Coke, I prefer the tank type, just be sure to mount it vertical!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2021 at 8:04am
I too prefer the tank type, I was just hoping that someone may have actually installed one and could give some specifics about it.
I ventured out yesterday and looked the machine over; the lower block drain is readily accessible but looks rather small. Not sure where to tap in on the thermostat housing area though.
The lower radiator hose looks to be the easiest but the highest wattage I can find readily available is only 600 watts. Hmmm... Confused
