Block cracks
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: Block cracks
    Posted: 02 Feb 2010 at 9:25pm
I got the block for my 59 D14 hot tanked and cleaned.  A hairline crack was found near the top between the 3rd and 4h cylinder.
I would like to confirm that this will not pose any problems.  If my memory serves me correct, a block that has a crack near the bottom is no good for anything (except meybe a boat anchor).
Thanks in advance for the feedback.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 9:27pm
This picture shows how I found it.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 9:31pm
It's rare to find a block w/o those cracks, well, maybe not rare, but the cracks are pretty common and are not a problem
mark-east-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 9:44pm
I ve got 2 0r 3 tractors  that are same way, cracked between cylinders and they run like a champ.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 6:58am
If it is hair line crack  most are no problem ,BUT it is not in front of me and I can not see how it is .Any close up pictures?.
If it is a hair line crack, when you drop sleeves with out  O-ring check sleeve height.Would not hert to deck block and cut counter bores.
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 7:32am
My B has them between 1&2 2&3 3&4 and the guy at the machine shop said they didnt hurt anything
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
archangel_cpj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote archangel_cpj Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 3:57pm
I think that like 90 percent of AC blocks cracked in that spt being a sleeved motor it poses no problems mines been that way for 20 years that I know of now I will put this caviate in when I did my overhaul a few years back before I put my head gasket back on I used a coper based spray gasket NAPA has for head gasket placement Ive used it since and on Head gaskets I replace good job
