Blending and separating oils. |
Coke
Topic: Blending and separating oils.Posted: 27 Oct 2020 at 5:41pm |
Got a couple of thoughts in my head. 1. I got a SBC full of diesel, that I need to drain. You think if I let the contents settle (after draining), I can siphon the diesel off from the motor oil, good enough to use it in my torpedo heater? 2.. Same SBC if I want to try starting it, it had 10W30 in it, I have a case of 5W30 and a couple of gallons of 15W40, all non-synthetic, think I could combine the two? |
1957 D17 Diesel w/ M&W Pistons
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54378 |
Posted: 27 Oct 2020 at 5:48pm |
One question, What is SBC? Small block chevvy?
1. I doubt it. Likely it'll smoke you outta the shop! 2. Maybe, never tried it, much, but some oil in a motor is better than no oil, in a motor...
Coke
Posted: 27 Oct 2020 at 5:51pm |
Yeah it locked up bad, I have an actual diesel block (379) to replace it now, but I had filled it with diesel to see if it would loosen up. It's been sitting a couple of years now. Bummer. It takes a lot of diesel to fill a block, seems a shame to waste it.
Joined: 11 Sep 2009 Location: illinois Points: 88429 |
Posted: 27 Oct 2020 at 5:59pm |
If it has been setting 2 years, drain off 6 quarts and see if it looks like "oil"... then drain the rest and see if it looks more like "diesel".... Most conventional oils will mix and not seperate.. Combining 5 w 30 , 10w30 and 15w 40 should not be a problem... You are running this as a TEST anyway... eventually it will be drained and refilled... no problem.
Edited by steve(ill) - 27 Oct 2020 at 6:03pm |
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8147 |
Thanks(1)
Posted: 27 Oct 2020 at 6:32pm |
See if I follow here;
You filled an engine crankcase with diesel fuel? There was still motor oil in the crankcase when you filled it with diesel? You want to try and separate the motor oil from the diesel? Then you want to take that diesel that was in the crankcase and use in a heater? |
shameless dude
Posted: 28 Oct 2020 at 3:50am |
use it for a brush pile
Coke
Posted: 28 Oct 2020 at 8:12am |
How? And I mean this in all seriousness. We had a tornado during the summer, and I lost a couple of trees and a lot of branches. The D17 proved it's worth even managing to knock one of the high branches out, and hauling and stacking it all up (and yeah a neighbour came by with his Case and prettied it up) but I have no idea how to set a big pile burning safely. Use diesel?
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4120 |
Posted: 28 Oct 2020 at 8:34am |
That's what I do with fuel like that, down to about a gallon of fire starter now.
Coke
Posted: 28 Oct 2020 at 9:03am |
I can see gas as a firestarter, but diesel?
farmboy520
Joined: 22 Jun 2016 Location: Beason, IL Points: 553 |
Posted: 28 Oct 2020 at 9:09am |
Diesel is safer to use as firestarter.
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
Posted: 28 Oct 2020 at 9:25am |
COke, NEVER use gasoline to start a fire.. The VAPORS will flash.... Pour old diesel over some small branches in your pile , or hand full of dry grass... You might use a couple sheets of news paper to get it to start.. The diesel will then light off...You can do this with waste oil also.
Edited by steve(ill) - 28 Oct 2020 at 9:26am |
john(MI)
Posted: 28 Oct 2020 at 10:38am |
Make a campfire teepee at the edge of the pile with some newspaper
under it. Make sure it's not a windy day. We are required to have a
burn permit here for anything larger than a campfire. We also need to
call the fire dept to see if it's okay to burn, or go on their website
to check. Pour the diesel on the area you
are going to start the fire. Walk back to the barn to get the matches
to start the fire. Return to pile and start fire. This allows the
diesel to soak into the wood. I always put a back clade on the tractor
and turn it around backwards. When the fir starts getting small I push
he edges of the pile into the middle. You can usually get the bulk of
the stuff burned up. |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8667 |
Posted: 28 Oct 2020 at 1:08pm |
Diesel in a hand pump sprayer will get it screaming in a hurry after initial start!! Fire will follow your spray. You can get enough heat from a large flare to really get things going.
Grayray
Joined: 12 Sep 2009 Location: Ambridge PA Points: 3858 |
Posted: 28 Oct 2020 at 3:06pm |
Don't ever use gasoline to start a fire. It is way too dangerous. The flash point of gasoline (point that it gives off combustible fumes) is -40 degrees F. That means that the second that you pour the gas on the pile, it starts vaporizing and you don't know where those vapors are. When you light it, it goes up very fast, almost explosively.
Diesel, heating fuel, and kerosene have flash points around 120 - 130 degrees F. They need to be heated some before they give off combustible vapors. This makes them light much more slowly and much more safely. Many years ago, as a volunteer firefighter, we had a case of a 16 year old high school student that tried to light a camp fire with gasoline. He splashed some on his clothing without realizing it. When he lit the fire, his cloths caught fire as well. Without going into the nasty details, let's just say that he died a few hours later. Not a pretty sight. Please don't do this to yourself. This may also help to understand the dangers: [TUBE]BCXjlshi770[/TUBE]
JohnColo
Joined: 03 Apr 2020 Location: Niwot, CO Points: 1263 |
Posted: 28 Oct 2020 at 8:44pm |
I have used old gas to start a fire, BUT, I pour some on some pieces of wood and let them dry out overnight, then I light them with some newspaper. BTW, I'm talking a small amount of gas, like a pint or so. Smells so bad I doubt it has all that much energy in it anymore.
shameless dude
Posted: 28 Oct 2020 at 10:06pm |
i burn alot of green or just cut live branchs and pile it up, i also use diesel in a hand pump sprayer, green brush has to be packed pretty tight, then wad up some paper under a safe exit area, light the wad, spray some diesel there after it's lit, when the tree sap gets hot it'll burn on it's own, can spray more diesel around from the lit area to make it spread out and burn the pile faster. junk oil can be added to the diesel too.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 29 Oct 2020 at 7:32am |
Coke, use some of that diesel for a parts washer!!
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12243 |
Posted: 29 Oct 2020 at 9:15am |
A buddy of mine, very safety conscious guy, in fact a safety coordinator by trade, knew of the dangers of using gasoline to start a fire, but had "nothing else" so decided to try it very carefully.
His pile of leaves/twigs was probably 40 or 50 feet away from his little shed. Gasoline stored on a head-high shelf in the shed. He got the gas, poured it on the leaves, and took the gas back to the shed and put it on the shelf. Very still day. He lit the fire and watched in slow motion horrific amazement as the leaves lit and then the fire took off toward the shed! It got to the point where he swung the can up to the shelf, I guess moving fast enough it finally swirled the air and dispersed it and the flame went out, just a couple of feet from the can still with gas in it and would have blown and took his whole shed down in flames. It's funny now, he wasn't laughing that day. Never again he says!!! |
Coke
Posted: 29 Oct 2020 at 12:04pm |
I think y'all might have been using too much gas. ![]() I've never tried diesel, I've had people put out cigarettes in a pool of diesel (from my old car), I guess it's more of an accelerant than a starter the way y'all are talking about it. |
Posted: 29 Oct 2020 at 12:30pm |
like mentioned, the diesel has to be 130 degrees to BURN... pour some on a news paper and light the paper... then it burns... your right, you NORMALLY cant hold a match to a can of diesel and have it light
Tbone95
Posted: 29 Oct 2020 at 2:42pm |
I use it on my firewood for the first light of the year in the stove (diesel that is) even though you're not "supposed to" and I'm here to tell you, it does start one helluva fire. Throw a match in a pool of it, it will go out because there are no vapors. Let a match rest beside it for a bit to warm it up, it burns and burns hot in a hurry.
Amount of gas has nothing to do with it. Honestly I can't believe we're having this conversation as adults! No offense meant, but holy cow! |
Lars(wi)
Posted: 29 Oct 2020 at 5:47pm |
I’m surprised someone thinks motor oil, and diesel will not mix.
If I understand the OP correct. |
