blacktop |
pohlman249
Topic: blacktopPosted: 19 Jul 2014 at 10:19am |
Whell I finally got my series one D17 most of the way done. The M&W group has our blacktop pull today in Rushford MN going to run 4500 5500 with it. If I get to the dyno I'll probably be dq though even though it's an agco dealer running the dyno. Hope to figure out how to get the pictures loaded on hear.
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Posted: 19 Jul 2014 at 12:27pm |
why would they DQ you?
How much HP you think is in that 226? :) |
Charlie
pohlman249
Posted: 20 Jul 2014 at 12:43am |
Only allowed 45hp in 4500 lb class. Spun out in 4th gear "3rd low" in 4500 but had pretty good load on the motor. 5500 which is 55 hp I spun in 3rd "2nd low". Beat a few M farmalls with road worn 18.4 and 20.8 38 tuner on pressed steel with my little 16.9 28 mismatched tires... Also found out 200 allis with a p pump shoehorned in doesn't do good in a 6700 lb class due to tire limited to make weight...
Edited by pohlman249 - 20 Jul 2014 at 12:45am |
