BKT tires
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Topic: BKT tires
    Posted: 01 Feb 2026 at 8:00pm
Just put a set of new BKT 14.9-28 tires on my WD.   Anybody know if they're wort a chit? I guess it's too late now as I already got 'em.  Any opinions on that brand?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2026 at 8:19pm
I put on the exact same set of BKT's 12 years ago on my WD-45. Been very pleased. Tractor rides every summer maybe 250 to 300 miles and pull a 3 x 14's mounted plow when I can find a place to play. Always have traction. Haven't been disappointed at all. Good physical height too.
Edited by DrAllis - 01 Feb 2026 at 11:08pm
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2026 at 8:28pm
I have them on all my G’s, most are 15+ years old, no cracks so far, I find them a bit harder than a lot of others, but I’ve been happy with them, and usually are priced good
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2026 at 12:37am
I've a set of 18.4x28" on an AC180 no issues good traction been in use about 12 years. IF memory is correct has a couple less bars than on Firestones but still taller than goodyear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2026 at 8:05pm
Yes Doc I like the height too.  Thanks all for the replies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2026 at 8:22pm
For tractor rides and no fluid or weights, I run 10 psi of air. When I plow, 12 psi works well and I hang 900 lbs of weights on a belly rack directly in line with the PTO box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2026 at 9:45pm
I’ve got BKT’s on my 190XT and I really like them.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2026 at 3:19pm
I have several tractors with BKTs.  No problems so far.
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2026 at 5:50pm
About the best for the money. Unless you can justify or want Michelin radial tires on a play tractor
