Biodiesel
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Topic: Biodiesel
    Posted: 08 Feb 2010 at 6:35am
The old diesel powered extendaboom rig we have been using on the new shop has been occasionally sputering and finally died yesterday. Leave the retrofit electric fuel pump run for a while and the rig fires right up... for a couple seconds. No the tank is not empty. I'm leaning towards the fuel filter being plugged but am open to other suggestions...
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 7:03am
Plugged primary filter or injecter pump. Some of the Rosa Masters injector pumps will do this if they are bad. Also old fuel will get alge in it and plug things up real quick. If you are tying to run a vegatable oil as diesal with out cleaning the tank. it will act as a solvent and plug up filters
Edited by Dave A - 08 Feb 2010 at 7:06am
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
