Billet Blocks
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Topic: Billet Blocks
    Posted: 19 Feb 2025 at 8:38am
Saw an interview with a NFMS New Holland tractor owner. Pro-stock. Mentioned billet iron and aluminum blocks.  Max CI per rules. Wonder what the cost would be for a billet block - customer cylinder head, crank, rods, pistons etc ? Component chassis, the limited pro had to have only an IH bell housing.  And this is 'tractor pulling' ?  Would suggest it is simply modified class with tractor sheet metal. My argument is from the 'stands' the folk that pay, it was much more entertaining in the '70's  and early 80's over today - at least to this fan. It is like any other sport - money, money and more money over individual talent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2025 at 8:46am
I remember talking to Dana Monson 25 or more years ago. He used to pull an IH twin Turbo Super Stocker on the NTPA circuit. He finally quit because of the $$$$ required to keep up. He said that most fans in the stands couldn't tell if a tractor was turning the rear wheels 45 mph or 75 mph, and that's all the more $$$ and HP did.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2025 at 10:22am
My point exactly.  Like story with NASCAR.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2025 at 11:07am
Today's heavy weight Super Stock diesel NTPA caliber tractors have to make 4500 HP to be a winner. Then, there is the Ross Family tractor, a McCormick looking sheet metal tractor called "Triple-Bypass" (3 turbos) that is reportedly making right at the 5,000 HP number. And when you see him run, you would believe it.  They have to have billet blocks and cranks !!!   Google: Colin Ross Triple Bypass in the sand NFMS
Edited by DrAllis - 19 Feb 2025 at 11:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2025 at 3:06pm
Calling them Super-Stocks is about like putting puppies in the oven and calling them biscuits.  Truth is they are modifieds, there are hardly any "TRACTOR" parts on them.
  I'm not saying they aren't impressive, they most certainly are. There's just nothing except the hoods  and a single 6 or 8 cylinder engine to resemble a TRACTOR.
  Back in the early 80s the rule change to allow a "component tractor" should have never happened.  I understand the desire to build some reliability into them, however making everything work within the constraints of a true "tractor" is impressive in its own right.
 Also the big money factor has killed the individuality and ingenuity as most everyone buys their ready to run or parts from the same places.
  This started in the late 70s when many also-ran racers got into pulling. Here locally we all were putting a junkyard V8 into a fencerow tractor and we were all having fun. My last year of running a modified I had 2 blown injected engines that needed to be rebuilt and then add a 3rd just to keep up with the the east coast region of NTPA.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2025 at 8:50pm
i have to agree with everything every one has said,       pullers from the the 70s trips my trigger because they are still farm tractors that were souped up with tractor parts.   but race on sunday and sell on monday is gone.    even this antquie pullers is getting way out thier cost wise with billit this and billit that
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2025 at 5:38am
I have no idea why people use the term 'billet' for so many 'performance' parts...
There's ingots, blooms, billets, and slabs...  all part of the raw material metallurgy process, and production of materials in the EARLY stage, they'd never be used raw...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2025 at 7:57am
Local farm near to here, was big into pulling and drag tractors, got so far into that had to be sponsored to achieve enough cash beyond where he could impart, sad part is it all fell apart, bad year at farm, at crop recovery, barn fire, so many machine debts lost it all.  Went to Auction mid month and all has left is a small house a pickup and some odds and ends.  Not certain if the family went or if still around.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2025 at 12:05pm
I hear ya Dave- back in the 80,s I seen a sale bill in the paper of a complete farm auction - had a hot ONE EIGHTY on it- was around your area- ran all over the country as the farm fell apart,,
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2025 at 1:42pm
It started when the first guy tweaked his tractor to beat his neighbor. It's just grown from there. As horsepower increased and cubic inch limits were set. Studs girdles and deck plates weren't enough to keep stock blocks together. Transmissions were replaced with overdrive gears that were stronger, just like in our deer allies, power directors were removed. Rear Ends beefed up and brakes needed upgrades. It's just natural progression. Improvements were made for performance and safety. In some cases there was a thought of cost savings verses trying to adapt factory parts. Also to level the playing field as some brands heads don't flow as good as others. It is a money pit but so is any other professional sport.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2025 at 2:00pm
Tractor pulling is just like buying a horse the initial purchase is just the start. Getting a hauler and traveling all over, having the time to do it. Repairing damage if you chose to chase season points.
This page was generated in 0.387 seconds.
