Big 10 starter mounting
Dwayne TX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dwayne TX Quote  Post ReplyReply Direct Link To This Post Topic: Big 10 starter mounting
    Posted: 23 Oct 2014 at 3:42pm
My Big 10 was partially taken apart when I got it.  When I went to put the starter/generator on, the pulley won't line up.  If I put the ears inside the bracket, the pulley sits too far forward.  If I line the pulleys up, it looks like it needs a spacer between the starter and the front of the bracket.  What am I missing?
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2014 at 4:23pm
Sounds like someone changed something. All original generators fit with pulley end on outside of mounting bracket tab and other end on inside. B110's and up have different mounting bracket and both generator tabs fit on outside of bracket. Attached is picture of one our B10's.
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2014 at 9:09pm
Sorry it took so long, been rather busy. Here is a picture of mine, looks the same as above.
The mechanic always wins.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2014 at 7:49pm
 probably wrong starter   is it correct rotation?????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dwayne TX Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2014 at 1:14pm
The one that came with it is Delco 1101974, which looks like only a genset.  I guess I need to get the correct Delco number and find the correct one.  Anyone got one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2014 at 2:25pm
Sorry I should have listed the number! 1101980 is on B10s,12's and the 1101689 is used on B110's and 1112's. Either one will work!
This page was generated in 0.563 seconds.
