Bevel Gear Box
Albow44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albow44 Quote  Post ReplyReply Direct Link To This Post Topic: Bevel Gear Box
    Posted: 11 Dec 2020 at 5:21pm
Hey all, I'm in the process of getting my 712 Shuttle ready for the winter plow season and I'd like to change the BGB Oil. The manual states to fill it up to the "end of the dip stick". How much Gear Oil is that approximately? I have a giant jug, and I don't want to pour out more than I have to and I'm not seeing an estimated amount anywhere online.
Thanks in advance.
Alan
Post Options Post Options   Thanks (1) Thanks(1)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2020 at 10:29pm
I don’t have a a manual on that tractor. Try a pint at a time, after 1 pint check it. If not on the dipstick add some more. Go a 1/2 pint at a time. Slow pour once it hits the dipstick until full. A little research will get you the proper info. Just guessing here when I am unsure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albow44 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2020 at 8:51am
Thanks. I guess I'll try that. I haven't been able to find an exact amount anywhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2020 at 3:49pm
hmm.. you could measure the BGB, figure out the volume, cut in 1/2 and guesstimate that _might_ be close to the volume ?? Say the BGB is 8x8x8 inches. that's about .3 cuft or 20 pints...,/2 ( volume of gears+shafts.... makes about 10 pint needed.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2020 at 5:31pm
It's less than a quart I changed my simplicity used a quart bottle had quite a bit left. The rest filled my JD gear box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albow44 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2020 at 5:58pm
@Dakota Dave, You are correct, I filled it today. Its about 3/4 of a quart.
Thanks All!
