Best way,,,,,, |
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8402 |
Topic: Best way,,,,,,Posted: 08 Sep 2022 at 11:38am |
To separate coolant out of used oil?
Have a 8,000 gal storage for used oil, about 20 in on the bottom is red coolant, from oil changing, leaking oil coolers etc. Not all engine oil, some gear oil, hyd fluid, diesel etc. stuck a suction pipe down, and pumped out till black showed coming out nozzle, but has the consistency of water. Gonna fill a couple totes of this mix, and see if it will separate out. Are there any other tricks to this? The oil recyclers don’t want any coolant in the batch. Thanks in advance. |
plummerscarin
Posted: 08 Sep 2022 at 12:31pm |
Drain valve/plug at the bottom of the tank. Open just enough for the water/coolant to come out first. Don’t know if all can separated if emulsified
Lars(wi)
Posted: 08 Sep 2022 at 1:07pm |
Unfortunately no drain plug on bottom of tank.
Joined: 11 Sep 2009 Location: illinois Points: 90811 |
Posted: 08 Sep 2022 at 3:29pm |
engine oil will separate from water / antifreeze if allowed to set... Many hydraulic oils are made to hold water in suspension.. they dont seperate... All you can do is slowly suck the good oil off the top or put a long tube and suck the mix off the bottom.... its not going to be pretty.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25253 |
Posted: 08 Sep 2022 at 3:39pm |
re: Unfortunately no drain plug on bottom of tank. OK, I HAVE to ask WHO decided to NOT have a drain plug in an 8,000 GALLON tank ??
Lars(wi)
Posted: 08 Sep 2022 at 4:12pm |
That, I have no clue. Tank is probably 30 yrs old. There is an outlet valve on one end, about 6-8 inches up from the bottom, but for a drain plug on the ‘belly’ of the tank there is not. |
