Best way…………..
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Best way…………..
    Posted: 22 Mar 2022 at 3:50pm
to remove paint from an aluminum rim?
22.5 aluminum rim, years ago got painted black. Other than dismounting the tire, and switching rims, what is an easy, effective method of removing paint from an aluminum rim? TIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2022 at 4:16pm
I put a couple coats of paint remover on and get off as much as possible with a wire brush... Then use a sand blaster... If tire is too big to go in the blaster, build a small plywood or cardboard box over it and a plastic window to look thru.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2022 at 5:57pm
Walnut shells for blasting if paint stripper don't work. Less damage to wheel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2022 at 6:49pm
Will give paint stripper, and oven cleaner a try. If they don’t work, then I’ll switch rims, don’t have a blaster.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2022 at 7:43pm
call a local shop.. If you get 80% of it off with the stripper, they may not charge much to finish it.
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2022 at 9:02pm
Kinda depends n what finish you want to end up with. Easiest way would be to sand it off with a random orbit sander. Start with 60 grit paper and work your way up to 220 grit. Will leave a nice smooth finish that is easy to polish.
For polishing I use a 5" variable speed sander/polisher from Harbor Freight with a 6" sewn cotton buffing wheel and a stick of red polishing rouge. With a little time, you can make it shine like a mirror.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2022 at 10:00pm
Don’t need it shine like a mirror, as it’s a company delivery truck. A 1995 KW T800 w/3406e, and Eaton Super 10.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2022 at 1:16am
folks around here take their rims to the local monument company to have them blasted. dunno what they would charge, but they keep going back so maybe it ain't to spensive?
This page was generated in 0.703 seconds.
