Best way to tap……….. |
Lars(wi) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Permian Basin Points: 7733 |
![]() ![]() ![]() ![]() ![]() Posted: 6 hours 29 minutes ago at 7:05pm |
into PEX(3/4”), with cpvc. I don’t have a pex crimper, or any pex tools for that matter. Never worked with pex before. This will be a hot water extension from bathroom supply to laundry room. Or, would I be better off using pex, and getting the crimping tool, and stuff. The pex in the home is the blue(cold) and red(hot) TIA.
Edited by Lars(wi) - 5 hours 48 minutes ago at 7:46pm |
Pat the Plumber CIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Springfield,Il Points: 4872 |
Shark bite fitting will easily connect the 2 . Be sure and use the plastic insert that comes with the fitting on the pex side . You don't need it on the pvc side.
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 85582 |
forget the CPVC... nothing but problems when it get OLD and BRITTLE, or froze... the PEX works great... I have a crimper and go that route.. Have used a couple shark bits and they are easy..
