BEST PULLING TRACTOR FOR THE BUCK |
Post Reply | Page <123 |
wrightk20
Bronze Level Joined: 04 Jul 2010 Location: wisconsin Points: 52 |
dear moderator, please get rid of mlpankey!
WCCLASON
Silver Level Joined: 01 Jan 2010 Location: Viroqua Wi Points: 106 |
I would vote for Unstyled WC. I took both motors and built them up. Both are running 65 to 75 hp. I like the diffrent look of them. Not alot of people have them around my area. I have two. one is going on four years same motor, and the other one i am in the middle of working on the motor. Want to have one to keep playing with....and alot going to have it all painted up for this summers pulling season.......Hope things change on here soon becuase i am to the point of not asking any opinions because you dont know whats fact or BS.
I have a few i talk to and thats it anymore.
patrickmull
Orange Level Joined: 11 Jan 2011 Location: Casey IL Points: 893 |
wcclason what kind of hubs do you have on the front
WCCLASON
Some unstyled WC had a 6 bolt front end. That's what I have. Not sure why though...
Dipstick In
Orange Level Joined: 11 Sep 2009 Location: Remington, In. Points: 8602 |
They used them in 1937 and then went back to 5 hole after that.
WCCLASON
The tractor I have is a 38..serial number checks out and the tractor was un change. Had cultivators on it for its whole life.Stayed on the same farm since new. Was an all pressed steel wheel tractor I guess u could say from factory....kinda rare for 38?
mlpankey
Orange Level Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
WCCLASON
Thanks(1)
And back to the topic of the conversation....You can have a great power to weight ratio with a unstyled WC. Not much can touch one in a 3500 lb class.
And another note....Has anyone ever thought of the amount of driveline power loss in a WC compaired to the WD WD45? Just a thought.....WC has Bell housing then a pretty simple trans. Then a tourqe tub then right into the rear axle housing. On a WD you also have the cam system that runs the hydro pump . Just seems like more rotating mass for you to lose HP in the drive line? Im sure its not much but maybe i am over thinking it.
THE-MAN
Silver Level Joined: 11 Mar 2013 Location: By the lake Points: 156 |
Dont forget that drop axles are a very efficient transfer of power. Id stick it out with a WC, if you can turn the high gear ratio. Simple and Cheap
Orange Level Access Joined: 12 Sep 2009 Points: 19747 |
With the hydraulic pump and PTO gears and hand clutch removed, a WD or WD45 efficiency is the same as a WC. In fact an old WD transmission is the same as a WC, only located farther back in the chassis. The outboard (dropped) final drives have no advantage over any other bull gear design for power transfer.
THE-MAN
I was under the impression that it was slightly more efficient than other designs. I certainly like the hitch options because ofvthe added height.
WCCLASON
Great input guys. this is why i read the fourm! I kinda forgot you could strip all that crap out of the wd trans. That would help alot. All i know is radiator work is esxpensive for them! i can just go to the internet and buy a new radiator assembly. |
WCCLASON
Sorry...to early yet.... Forum**
cotncrzy
Orange Level Joined: 07 Oct 2009 Location: TENNESSEE Points: 599 |
If I could of found one I would of had a WC. They are rare birds around here. My great uncle had one, unstyled, I think a '37. I finally got it after he passed away. I bought it from my great aunt for scrap price, without really looking at it. To make this post short and to the point, Engine ,trans, was full of water and had a busted trans. housing. All the bearings were siezed in the rear which was also full of water. I just didn't think it was worth the trouble, salvage yard had very limited suppy of parts, looked like a money pit, I lost $50 on it, end of story. I wish I had it to do over.....
They are almost impossible to beat in the 3500# class, but it has been done! Stripped down I bet one weighs less than 3000#, that allows for moveable weight to balance the tractor. I run a WD, stripped, it weighs 3300# my son drives it in the 3500, most pulls allow 100# tolorance on scales so we can weigh 3600# We can run 65 to 100 # depending on how the scales weigh where you are at.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
michaelwis
Orange Level Joined: 12 Sep 2009 Location: Wi Points: 8765 |
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60 GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
WCCLASON
i was just looking at the pictures on that site and a few of them are pulls i go to...! maybe il see you around! what do you pull.. Michael?
michaelwis
Used to do ok with my 7040 being i,m an antique , thought i might as well pull with one
