Best Practices for Winterizing Allis-Chalmers Trac |
Post Reply |
elitecontainer
Bronze Level Joined: 21 Jul 2024 Location: California Points: 8 |
Posted: 21 Jul 2024 at 5:16pm |
Hey Allis-Chalmers enthusiasts,
With winter approaching, I wanted to share some tips for winterizing our tractors:
What are your winterizing routines? Looking forward to hearing your tips! |
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 22252 |
4. Raise tractor up on blocks,so no weight on tires/tubes/rims
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 80142 |
no need to drain anything.. get antifreeze down to -20 degree level ( or lower if your in COLD area)... charge battery with tender and leave in the tractor.. no blocks, it can set for 3-4 months... run the fuel down as low as possible.. add stabalizer to the las gallon if you want.. i dont bother and have had no problems.
Edited by steve(ill) - 21 Jul 2024 at 6:18pm |
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4593 |
My personal opinion is if I was going to drain (change) fluids, I would rather do it in the spring, just before I was going to use it, so any condensation is drained out. I do watch for milky fluids.
My tractors don't get enough hours on them to even change oil every year. Some are lucky to get 5 hours of actual run time in a year.
ac hunter
Orange Level Joined: 05 Jan 2011 Location: OHIO Points: 976 |
So WF, how often should one change oil in a tractor that only runs a few hours per year? I have the same problem; they are stored in an insulated building and rarely does the temperature get below freezing. Thanks.
Lars(wi)
Orange Level Access Joined: 14 Sep 2009 Location: Permian Basin Points: 7071 |
Winter approaching? Check your calendar, it’s July where I am.
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11742 |
Run the fuel in the tank way down. Add some Stabil in the fuel tank. Drain the Carburetor and fuel line completely Pull the Battery and put it on a Battery tender in the wire shop Air the tires up a little higher than I would normally have em'. If sitting outside, I put a 4 mil plastic zip bag over the Alternator or Gennie Give it a good coat of wax on it for the Winter months. I do the same thing with my Antique cars. But I put the cars on jack stands to get the weight off the tires to eliminate flat spots. I leave the Antifreeze in all the Tractors and vehicles.... Steve@B&B |
Post Reply | |
