best carb |
big d
Topic: best carbPosted: 09 Feb 2015 at 8:54pm |
I have a wd45 with a 226 what is the best down draft carb for pulling
mattb
Posted: 10 Feb 2015 at 8:02am |
don't know where your from but most places make you use updraft carb
big d
Posted: 10 Feb 2015 at 6:00pm |
I live in tn and the pulls around here at least the ones I pull in allow it
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Posted: 11 Feb 2015 at 6:02am |
Did you design a whole new manifold?
Charlie
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4071 |
Posted: 11 Feb 2015 at 6:04pm |
wonder if he really means up draft
Posted: 11 Feb 2015 at 6:40pm |
Just another wannabe puller who thinks something as simple as a different carb will double the HP of his engine??
big d
Posted: 11 Feb 2015 at 9:25pm |
No I'm not just another wannabe puller I have ported the head I have 4/18 overbore m&w pistons a custom header 3 angle valve job and the crank has been offset with wd45 diesel rods and a reground can changed over to electronic ignition with a 50,000 volt coil no I didn't mean updraft carb it has a zenith on it now that has a bigger jet so I know a little bit about pulling
Posted: 12 Feb 2015 at 5:42am |
Well then, you'll have to ask one of your competitors what they recommend as the "best" down-draft carb for your specific application. Where I come from, there isn't such a class with down-draft carbs and no governor control of the engine speed. Good luck. Sure hope you used SP-46 pistons for a good compression ratio. The rods you used are actually shorter in length than a stock OEM rod.
Hudsonator
Joined: 21 Oct 2009 Location: Tennessee Points: 2113 |
Posted: 12 Feb 2015 at 8:07am |
Where in Tennessee are you? |
There isn't much a WC can't do.
WD's just do it better. |
big d
Posted: 12 Feb 2015 at 8:10am |
East tn I live in Grainger county which is about 45 above knoxville
HudCo
Posted: 12 Feb 2015 at 9:08am |
2bbl holley
Hudsonator
Posted: 13 Feb 2015 at 3:33pm |
Marvel made a 2 barrel side-draft, very small venturis, that went on Massey Ferguson 310 combines equipped with the mopar slant six.
I think we have a couple of them (side draft marvels) around. I'd like to see a picture of that manifold. Seems I did hear of a Heisler intake for a W that used a side-draft carb. Never saw one in person. |
HudCo
Posted: 13 Feb 2015 at 6:12pm |
thought that dr. allis had a manifold with no carb i would like to see a picture also
JayIN
Posted: 14 Feb 2015 at 7:47am |
I thought he said he had diesel rods with a offset crank. So what if the diesel rods are a little shorter....maybe the crank throws higher now........or his wrist pin height has changed. Who knows what pistons he is using. Good luck , sir. I CANT JUDGE YOU.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 17 Feb 2015 at 6:45am |
Said he did. I e-mailed him bout' the manifold last week when he mentioned it. Didn't hear from him at all on it....
Steve@B&B |
Steve in NJ
Posted: 17 Feb 2015 at 6:59am |
I'm curious about your down draft manifold. Something you designed or someone you know designed? If so, what carburetors are the competitors running? Just curious. I like different approaches to high performance modifications being I'm a hotrodder by heart. Makes things interesting. I would think it wouldn't be to tough. My old racing partner and I made a couple sheetmetal intakes for inline Chevy sixes back in the late 60's for a couple customer's Drag Cars we experimented with. One manifold we designed handled two Holley 390 cfm carburetors mounted sideways. The other was a tunnel ram style manifold with a 750 double pumper Holley sittin' on top. The single with the 750 actually worked better. Was a lot of fun experimenting with those. Later Jack Clifford of famous Clifford Research came out with some neat "bolt-on" manifolds for the inlines...
Steve@B&B |
