Best brand of oil filters
Darwin W. Kurtz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Topic: Best brand of oil filters
    Posted: 20 Jul 2021 at 11:24pm
wondering which kind you think is best
I tend to use mostly Wix, (Wix is locally available with a great dealer) some Baldwin or Hastings, & Motorcrafts (Motorcraft for our Ford)
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 11:51pm
I put on hundreds of oil filters while we had our business. NAPA gold were heavier than all other brands. The only problem we ever saw, the dang gaskets stick to the block.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 6:03am
Wix  is certainly one of the better ones. Napa gold is made by wix.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 6:35am
The only vehicle I routinely change myself is our class A motorhome. Most of the time I get the Motorcraft, or a Wix.
At work, 95% of the filters on the trucks, and frac equipment have Baldwin, with a few Donaldson thrown in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 8:36am
Filters is like arguing about oil or trucks... All the BRAND NAMES are comparable. A lot depends on what your local supplier sells or where you shop.
I do buy FORD filters for our vehicles. Had troubles 20 years ago with one ticking on startup.. The FORD had anti drain back valve in it.. Fixed the TICK.. Never changed back to anything else.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 1:19pm
Wix, Baldwin, Hastings are the top manufactures. Wix markets under a lot of different names. So does Fram. Non of them make all their own filters. They source certain types from others. Baldwin supplies alot of of hydraulic filters to other manufactures.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 5:32pm
I have been using Fram for years and have not had any troubles.  I even got a bunch for my AC's.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2021 at 8:27pm
Believe it or not, I get a GENUINE MOTORCRAFT 820S filter at my local Walmart or the Rural King for $ 3.97 Wink
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2021 at 9:56pm
For my farm equipment I use either Wix or Baldwin whichever my supplier has in stocks. For our car and truck I take them to a local Mechanic Garage to change oil. Too low for me to crawl under!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2021 at 4:54am
Worked as a mechanic some 20+ years, would not install a FRAM on a bet.  Would cut filters open as a engine failure occurred where a great deal of FRAM or other Cheap filters failed the inspections.
I use Baldwin, WIX, Motorcraft(Ford Sold) and CAT branded filters, for heavier later machines FLEETGUARD is another.  Used AC(GM Line) for a long time but unable to get them locally anymore and Goodwrench seems to be the replacement name.
Edited by DMiller - 23 Jul 2021 at 4:57am
modirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2021 at 9:41am
Who makes AGCO filters?
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2021 at 11:04am
Wink The guy making them the cheapest.LOL
This page was generated in 0.227 seconds.
