Best 300 series Flex head 313 Feather sheets?
Meanolallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meanolallis Quote  Post ReplyReply Direct Link To This Post Topic: Best 300 series Flex head 313 Feather sheets?
    Posted: 26 Sep 2016 at 10:00am
I have a 313 flex head that needs new feather sheets and I am looking for a recommendation of what works best. I did some reading on other forums and it sounds like stainless from Shoup (~$450) and Poly ($400?) have a tendency to be stiff and heavy? Anyone have good luck with them? It also sounded like the raised single piece sheets from a 500 series will fit on a 300 and work really well. Any idea what part numbers I would need to order to do this? Maybe I'd have to trim feather sheets for a 15' down to fit on a 313???
What about original sheets from Agco? Would they work as well and be competitively priced?
I have a lot of rocks in my ground and a Tigerjaw cutter bar if that affects anything.
Thanks for the advice!
Peter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meanolallis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 1:22pm
I did find an older post with a similar question: http://www.allischalmers.com/forum/forum_posts.asp?TID=115623&title=313-flex-head
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 3:01pm
I still love the one piece feather sheets!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 3:52pm
Put a 2 or 3 inch flexible hose behind the cut bar if you don't already have it.
Wink
I am a Russian Bot
This page was generated in 0.150 seconds.
