Belt Questions 912
Hubcap View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubcap Quote  Post ReplyReply Direct Link To This Post Topic: Belt Questions 912
    Posted: 24 Feb 2015 at 8:23pm
What would usually cause the belts to come off the pulleys ? In particular when shifting from hi to low ? I replaced the low gear belt today. The high gear belt I did not replace because it looks ok. Will one new belt cause another used belt to come off a pulley ?
Looks like there is some kind of rod with a spring on the end some kind of tensioner and there is a gap play at end of spring and both nuts are tightened as far as they can go down the threads.
Any feedback will be appreciated. Thanks
