Belt Pulley
Avigil2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Avigil2001 Quote  Post ReplyReply Direct Link To This Post Topic: Belt Pulley
    Posted: 25 Aug 2023 at 10:35pm
Hey Guys i just picked up a 1952 CA and have no clue what everything is! i have a belt pulley that was just handed to me what is it for and use? Can it stay off? Also i want to make sure i have the right fluids in it what engine oil should i put? is universal green coolant okay or is there something better? And what hydraulic fluid do i use? I am planning to use this tractor around the yard using discs and a box blade so if there is anything i should keep an eye out for since it will be used for work not play! Thanks guys!
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2023 at 11:19pm
Happy New Tractor Day!
Google for the owners manual pdf.
You'll need the 3pt working well.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2023 at 8:48am
Buy an operator's manual.  It will tell you everything you need to know.  They can be found cheap on e-bay
This page was generated in 0.184 seconds.
