bearing
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Topic: bearing
    Posted: 20 Oct 2015 at 8:45am
anyone have bearings for fan shaft on allis hd4 dozer at reasonable price ? part # 245114
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 9:45am
isn't it a 2 bolt flange bearing ?
if my picture of shaft and support brackets are close the bearing bolted to upright .
should be able to come up with something
Allis Chalmers HD4 fan shaft bearing part # 245114
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&cad=rja&uact=8&ved=0CC8QFjADahUKEwi6z-2vpdHIAhVI7WMKHUs6Dtc&url=http%3A%2F%2Fstephensequipment.com%2Fdatabase.html&usg=AFQjCNEGR69xfBkB6bnLYvGVBLRWxB_cCg&sig2=4raGrr4a9KxJ41K_fHd2_w
Edited by Coke-in-MN - 20 Oct 2015 at 9:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 11:20am
yes it is 2 bolt flange
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 9:11pm
any bearing house should be able to supply or measure shaft and might find at tractor supply or other farm service store .
 If I knew the shaft size I probably have some in my parts bin - have 400/500 bearing I got when shop closed - rather than trash them I figured some day I could use them - have fixed spindles on several mowers , built few other things with them but 2 1/2 " 4 bolt flange bearings for air handlers I have not come up with use for YET .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 9:50pm
thanks coke. I have not pressed the old bearings off yet. I do have an hd4 loader for spare parts and I pulled the fan shaft out. seems that the bearings had been replaced recently. they are tight so I installed it into the dozer. I still want to find two bearings for spares. they don't seem to last long.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2015 at 7:23pm
bearings are generic parts like bolts. Like COKE said, they sell the two bolt flange bearings at the local Farm Store, Bearing house, NAPA, etc....... you just have to measure the shaft size and bolt to bolt  center line dimension.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2015 at 8:34pm
thanks , will do
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 1:44pm
8 years and never had problem with those bearings - sold machine and never replaced them in full time i had it .
if they have went out before - look to see if mounting is loose or bent causing load problems or shaft is bent - that will destroy bearings fast if vibration or flexing of the shaft .
