B-C OIL PUMP
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Topic: B-C OIL PUMP
    Posted: 17 Feb 2012 at 8:03pm
ANYBODY HAVE A GOOD WAY TO TEST A B OR C OIL PUMP BEFORE INSTALLING IT IN THE TRACTOR?
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 12:26pm
Here is what I did Bruce. Took a piece of 3/8 rod and cut a notch in the end so it fits into the pump like the cam shaft does, then put the rod in the drill and spun the pump while it was submerged in the parts washer and fluid shot out the pipe on the top. I assume that means it's working but I won't know until I split my C and install it. Need to spin it counter clockwise. My pump won't hold a prime so hopefully this one will.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 12:56pm
quite often a pump that wont hold prime is loosing its suction due to a leak. Think of a  well pump that is running. Shut it off and you hope it holds prime. Poke a hole in the line, have a thread leaking, or bad check valve on the foot... and you loose prime. Look for similar problems in your oil line.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 3:55pm
  inspect it while it is out!!!!  possibly a bad    relief ball  just had one with a bad one
   will know if checked replace the ball
