b-c hyd pump
lgehring View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lgehring Quote  Post ReplyReply Direct Link To This Post Topic: b-c hyd pump
    Posted: 07 Feb 2011 at 6:59pm
 good evening, i loaned a friend my hyd pump for my C to check out his system.  turns out his is bad, wants to buy mine. what is a working used pump worth? it is my only spare.  don't know if i want to sell it. any info would be great, thanks
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 7:01pm
Charge him enough that he almost takes it back off.  Thats what friends are for.
Texas B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Texas B Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 7:13pm
Man - who needs enemies - but you gatta point - there are not many on the market and most say for parts only - I think there was one on ebay for $50 or so
Texas B 39
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 9:49am
I'm sure I've got a couple but the shipping would cost more than what I'd ask for the pump.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 10:09am
What I have done in those cases is to swap and rebuild the exchanged parts. You could check with Sandy Lake on part costs. Parts for those pumps add up kinda fast.  Not a lot to that type of a pump to rebuild. Might be the non working pump would only need a good cleaning inside.  I have had a few apart and I have found rust, crud and broken springs to be the cause of most of the problems. I have never found one that was not repairable myself. I am sure you could run across some that were junk.
